Best gaming mouse? HELP
Thundurh
177
I have been looking for so long for a gaming mouse. I bought the Razer Deathadder Chroma 3 days ago, and returned it. It produced too much sweat with the rubber grips and was uncomfortable. Does anyone know of any mice that are medium sized, a little heavy, rubberized grips, and wired. Thank you, and I really just do not know anymore. I know its mostly personal preference but what's your person preference?
I personally tend to like larger mice but then again I have a large hand but at home I currently am using the Logitech G502 Proteous core. It has customizeable weights so you can make it as heavy as you like, a great sensor and good software.
Before that I was using a Logitech G600 (mainly for MMOs) which is now my work mouse.
Alright, that sounds like a good mouse. I have 13 year old sized hands (15 in long) would that be too uncomfortable?
Okay. I will start looking into some of those mice. Sounds like Logitech is the way to go.
Wow, it's really looking solid. Are the side grips rubber, and if they are do they cause any sweat and are they actually grippy? Because the Deathadder's just caused sweat and slipperiness.
They are rubber but if you notice they are textured. I have never had my hands get sweaty and I live in AZ and start sweating at 80F. I like the mouse personally. I hope it works for you but make sure you have a good return policy. I think they carry them at Best Buy.
I can only show you what I like and hope it works for you too.
Okay. I'll read some reviews, thanks for recommending it. Also, how the hell do you get an Animated signature? I really want one
My signature is made by another person.
For mice, I personally have very sweaty hands during intensive gaming. The anti sweat material is almost a necessity for me on my G500s. The anti sweat material built into the g500s is crazy good, even though I have sweated on the thing countless times, it still looks almost brand new.
Oh yes. Just what I needed, I ordered it with Amazon Prime Now. Haha, it's coming within 2 hours from now. I'll give an update once I get it 😀
Okay so. My conclusion is that the mouse is very nice. My pinkie and ring finger do get a little uncomfortable, though. I like the rubber grips, and the button just in front of where your thumb rests gets in the way sometimes. Otherwise great mouse!
Ahhh I forget about the Sniper button. It is preset to basically drop your DPI (when held) to 200DPI so you have extra precision. You can easily change it in the software.
Glad you like it.
It is hard to find the perfect mouse. Even though I have liked all the mice I have ever bought, I still have yet to find one that fits perfectly for me due to my hand size.
