I don't know if you need the OS as you worded it ''yes Windows 7 Home premium" Does that mean yes you have windows 7 home premium ..or that you want that version?
I'm over your 900 budget simply due to the OS, ill change the options when you clarify.
Thank you both also will the i5 intel core processor handle streaming(will be using XSplit) and recording?(Dxtory) Also video editing(Sony Vegas Pro 12)
Yes i5 is totally fine for gaming and streaming. The i7 comes into play for video editing/ photoshop and other applications that would make sure of the hyperthreading
ah sorry for not answering if your floor is carpet a anti static mat is good(any brand dosent matter), a wristband on a carpet or hard floor(wood,tile,etc). or you can frequently touch a case with a psu plugged in it also works just as good. But getting the wristband or mat is handy if your really foucsed and forget to touch the case
