Best Gpu for mobo Ga-970A-D3
Apr 19, 2018
9
I have Gigabyte-970A-D3 Am3 and iam confuse Between nvidia or AmD Gpu cards i hope u recommend for me abetter one with good price and compatible with my mobo,thanks my suggest was RX 460 or Gtx 1050ti but idon’t know if they compatible or not ? My power supply was cooler master 460w and the cpu was fx6300 and have 24 rams team
All the Graphics cards which run on a PCIe x16 slot including Rx460 and GTX1050ti are compatible with your motherboard. If you are choosing between Rx460 and Gtx1050ti, Gtx1050ti is the better choice.
thanks, does it work with out bios update ??
