Best GPU for this Power Supply
OK, those are the cards I was looking at. So in the future there will be more powerful graphics cards that require lower amounts of power like these ones? Or are all the cards just going to be using more power?
And also would these cards be good enough for modern gaming for a couple of years?
if you already purchased the PSU then I would say a GTX 260/275 / HD 4870/4890 but you will eventually hit a wall if you try to use anything more powerfull....
if you have not purchased the PSU then spend a tad more on the if you want it to last you a couple of years w/o upgrading..... for 20 bucks more you can get a 650TX and IMO it is superior to most PSU's in the 650w range.....
