best GPU's for ground clearance
is that for me? Please explain?
It looks to me like they have concerns over hitting the battery.
Lets make sure we are all on the same page here.
Red = Battery
Blue = Capacitors
Orange = Crystal oscillators.
Green = Coils/Inductors
I see nothing in the way of a video card in this system(any of the 7770's should fit) as long as the wireless card is removed. The one swifty_morgan linked in this post is nice and short and would not even reach the end of the board(this is a good thing).
So you want a single slot card.
The battery (round metal circle next to the wireless card.) will not get hit by any cards
If you are not using the wireless card, you can just remove it or get a usb or pci one :)
If not, you will need to look for cards that are single slot for sure.
Red = Battery
Blue = Capacitors
no. not directed at you. already provided a link to a card that has a fan shroud that should not interfere with a high cap.......... but I see it's a battery. and I never had a battery hit any kind of pci or pci-e card before so assume any card will fit. if doubts........... buy a card with a small shroud instead of one that fully encases the pcb.
