Best Graphics card for $200-$300
Gtx 960 is a good graphics card for that price, and if you are willing to go with $350 you can get the gtx 970, which is really worth it. Although, i'll meed more info to help you out. What are your specs? Power supply? Motherboard CPU and Case? Also, what games do you plan on playing.
Us, then 970 is good. If you can give some bucks more for GTX 970 then it is recommended. For GTX 970, I will recommend this one:
http://pcpartpicker.com/part/evga-video-card-04gp42978kr
This has highest overclock 1.22 Ghz and definitely it is from EVGA, and EVGA really make good Graphics cards and the cooling system is also good. Get that. Good luck. It will really worth if you give 40 bucks for GTX 970. Get that. Good luck.
Mark :sol:
