Best graphics card for $300 to $400?
Hayden_9
Commendable
Aug 11, 2016
I want to upgrade my graphics card. right now I have a gforce gtx 770 and I have around $200 to $350ish dollars to spend. I have an AMD Radeon rx480 8 gigs on back order for $240 and I was thinking cancelling the back order and either buying a different card or buying a 480 on amazon in stock for $340. Should I keep waiting for the 480 to get back in stock on new egg? should I buy a different card and if so what card?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487261&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-Veeralava%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=6202798&SID=
http://www.nowinstock.net/computers/videocards/nvidia/gtx1060/
The GTX 1060 I like is also out of stock, but it's restocked 2-3 times per day. Were it me, I'd cancel the 480 and order the GTX 1060. I like the one that I hyperlinked above, but probably any would do. If you want that specific one then you can set an "auto notify" and a "notification" on NewEgg and NowInStock respectively. Also, I should mention that if you have you heart set on the RX 480 then you could use NowInStock to locate that card as well.
