Best Graphics Card For 300Ws
ahashan747
I have a HP Pavillion Computer With the listed specs; I need to know whats the best graphics card I can get with this computer. I read that the 750Ti is the best for this but would like your opinion and if its possible to link the recommended card to Newegg. The PSU is 300 Watts.
Computer Link: http://support.hp.com/us-en/document/c03933829
Specs:
Motherboard: MS-7778 (JasmineR)
CPU: AMD A8-6500 APU 3.50 GHz
RAM: 8.00 GB
System Type: 64-Bit Windows 8.1
PSU: 300 Watts
Hard Drive: 2TB
Thanks
-Ahashan
RealHardTech recommends 400W for the gtx750Ti. nVidia recommend 300W
RealHardTech -
gtx 730 - 300W
gt620 - 300W
gt520 - 300W
These last 2 are hardly better than integrated graphics.
The 300W is supposedly from a good quality PSU though.
If it was me, I'd be upgrading the PSU. If you can. Some HP are non-ATX. They have non-standard connectors eg on the motherboard.
Mostly here I find that it's not worth pursuing upgrading a pre-built. The makers go out of there way to make it hard to do. They want you to buy a new one instead.
