Best graphics card for build
eberleeeee
22
What would be the best graphics card for my build? I do moderate gaming, mainly WOW but I do plan on buying Borderlands when the money is available.
Here is my build:
Phenom II x2 550 BE
Asus M4A785TD-V EVO
4GB DDR3 OCZ Gold 1066MHz
Raidmax Smilodon Extreme Black Case
Antec Earthwatts EA380 PSU
WD Caviar Blue 320GB HD
I was planning on spending between $40 and $60 but I am open to all suggestions.
Those are the best cards in your price range. Depending on the resolution you plan on playing at you might want to consider upping your budget to around $100 for an HD4770/4850.
Thanks for the quick reply.
I was also wondering how good of a graphics card my PSU could handle in my set up?
