Best Graphics card for GA-G31M-ES2L
Gabe769
15
I just got this PC and it has a preety bad Graphics card , I can't even run GTA:SA ..
I tried running CS 1.6 (only game that came in my mind) and that runs on software mode (no OpenGL) and runs laggy (i think 20 fps).
Tell me what information about my computer should i write , and where do i get it from so you can tell me what gpu is good for me . I run Windows 7 Ultimate 32 bit , if that helps .
Well, you don't have a GPU and your CPU also doesn't have a GPU, the one with your chipset is very weak.
You should buy something cheap like RX550 or GTX 750Ti(used).
A program like Speccy will give much more information. Just from what you posted, you have a dual core CPU from a time when integrated graphics was very poor. This is why even CS doesn't perform well.
The good news is that you can play games like CS with that dual core. You will need a videocard though, but not an expensive one.
Also, if you can open the case of the computer and read the label on the power supply, do so. Make/model? That will help determine which videocard might work.
Summary
Operating System
Windows 7 Ultimate 32-bit
CPU
Intel Core 2 Duo E7400 @ 2.80GHz 38 °C
Wolfdale 45nm Technology
RAM
2,00GB Dual-Channel DDR2 @ 266MHz (4-4-4-12)
Motherboard
Gigabyte Technology Co. Ltd. G31M-ES2L (Socket 775) 30 °C
Graphics
Generic Non-PnP Monitor (1680x1050@60Hz)
Intel G33/G31 Express Chipset Family (Gigabyte)
Storage
149GB Hitachi HDS721616PLA380 ATA Device (SATA) 33 °C
149GB SAMSUNG HD161HJ ATA Device (SATA) 32 °C
Optical Drives
Optiarc DVD RW AD-5200A ATA Device
Audio
High Definition Audio Device
Operating System
Computer type: Desktop
Installation Date: 17.06.2017 15:56:04
Serial Number: FJGCP-4DFJD-GJY49-VJBQ7-HYRR2
Windows Security Center
User Account Control (UAC) Enabled
Notify level 2 - Default
Firewall Enabled
Antivirus Disabled
Windows Update
AutoUpdate Download Automatically and Install at Set Scheduled time
Schedule Frequency Every Day
Schedule Time 03:00
Windows Defender
Windows Defender Enabled
.NET Frameworks installed
v4.0 Client
v3.5 SP1
v3.0 SP2
v2.0 SP2
Internet Explorer
Version 8.0.7600.16385
PowerShell
Version 2.0
Environment Variables
USERPROFILE C:\Users\HP
SystemRoot C:\Windows
User Variables
TEMP C:\Users\HP\AppData\Local\Temp
TMP C:\Users\HP\AppData\Local\Temp
Machine Variables
ComSpec C:\Windows\system32\cmd.exe
DXSDK_DIR C:\Program Files\Microsoft DirectX SDK (June 2010)\
FP_NO_HOST_CHECK NO
NUMBER_OF_PROCESSORS 2
OS Windows_NT
Path C:\Windows\system32
C:\Windows
C:\Windows\System32\Wbem
C:\Windows\System32\WindowsPowerShell\v1.0\
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE x86
PROCESSOR_IDENTIFIER x86 Family 6 Model 23 Stepping 10, GenuineIntel
PROCESSOR_LEVEL 6
PROCESSOR_REVISION 170a
PSModulePath C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
TEMP C:\Windows\TEMP
TMP C:\Windows\TEMP
USERNAME SYSTEM
windir C:\Windows
Power Profile
Active power scheme Balanced
Hibernation Enabled
Turn Off Monitor after: (On AC Power) 10 min
Turn Off Hard Disk after: (On AC Power) 20 min
Suspend after: (On AC Power) 30 min
Screen saver Disabled
Uptime
Current Session
Current Time 19.06.2017 00:00:53
Current Uptime 4.032 sec (0 d, 01 h, 07 m, 12 s)
Last Boot Time 18.06.2017 22:53:41
Services
Running Application Experience
Running Application Information
Running Background Intelligent Transfer Service
Running Base Filtering Engine
Running CNG Key Isolation
Running COM+ Event System
Running Computer Browser
Running Cryptographic Services
Running DCOM Server Process Launcher
Running Desktop Window Manager Session Manager
Running DHCP Client
Running Diagnostic Policy Service
Running Diagnostic Service Host
Running Distributed Link Tracking Client
Running DNS Client
Running Function Discovery Provider Host
Running Function Discovery Resource Publication
Running Group Policy Client
Running HomeGroup Listener
Running HomeGroup Provider
Running Human Interface Device Access
Running IP Helper
Running MGABGEXE
Running Multimedia Class Scheduler
Running Network Connections
Running Network List Service
Running Network Location Awareness
Running Network Store Interface Service
Running NVIDIA Display Driver Service
Running NVIDIA Stereoscopic 3D Driver Service
Running Offline Files
Running Peer Name Resolution Protocol
Running Peer Networking Grouping
Running Peer Networking Identity Manager
Running Plug and Play
Running Power
Running Print Spooler
Running Program Compatibility Assistant Service
Running Remote Procedure Call (RPC)
Running RPC Endpoint Mapper
Running S3Funkey
Running S3LoadSv
Running Security Accounts Manager
Running Security Center
Running Server
Running Shell Hardware Detection
Running SSDP Discovery
Running Superfetch
Running System Event Notification Service
Running Task Scheduler
Running TCP/IP NetBIOS Helper
Running Themes
Running UPnP Device Host
Running User Profile Service
Running Windows Audio
Running Windows Audio Endpoint Builder
Running Windows Defender
Running Windows Event Log
Running Windows Firewall
Running Windows Font Cache Service
Running Windows Management Instrumentation
Running Windows Media Player Network Sharing Service
Running Windows Search
Running Windows Update
Running Workstation
Stopped ActiveX Installer (AxInstSV)
Stopped Adaptive Brightness
Stopped Application Identity
Stopped Application Layer Gateway Service
Stopped Application Management
Stopped BitLocker Drive Encryption Service
Stopped Block Level Backup Engine Service
Stopped Bluetooth Support Service
Stopped BranchCache
Stopped Certificate Propagation
Stopped COM+ System Application
Stopped Credential Manager
Stopped Diagnostic System Host
Stopped Disk Defragmenter
Stopped Distributed Transaction Coordinator
Stopped Encrypting File System (EFS)
Stopped Extensible Authentication Protocol
Stopped Fax
Stopped Health Key and Certificate Management
Stopped IKE and AuthIP IPsec Keying Modules
Stopped Interactive Services Detection
Stopped Internet Connection Sharing (ICS)
Stopped IPsec Policy Agent
Stopped KtmRm for Distributed Transaction Coordinator
Stopped Link-Layer Topology Discovery Mapper
Stopped Media Center Extender Service
Stopped Microsoft .NET Framework NGEN v2.0.50727_X86
Stopped Microsoft .NET Framework NGEN v4.0.30319_X86
Stopped Microsoft iSCSI Initiator Service
Stopped Microsoft Software Shadow Copy Provider
Stopped Net.Tcp Port Sharing Service
Stopped Netlogon
Stopped Network Access Protection Agent
Stopped Parental Controls
Stopped Performance Logs & Alerts
Stopped PnP-X IP Bus Enumerator
Stopped PNRP Machine Name Publication Service
Stopped Portable Device Enumerator Service
Stopped Problem Reports and Solutions Control Panel Support
Stopped Protected Storage
Stopped Quality Windows Audio Video Experience
Stopped Remote Access Auto Connection Manager
Stopped Remote Access Connection Manager
Stopped Remote Desktop Configuration
Stopped Remote Desktop Services
Stopped Remote Desktop Services UserMode Port Redirector
Stopped Remote Procedure Call (RPC) Locator
Stopped Remote Registry
Stopped Routing and Remote Access
Stopped Secondary Logon
Stopped Secure Socket Tunneling Protocol Service
Stopped Serviciul Google Update (gupdate)
Stopped Serviciul Google Update (gupdatem)
Stopped Smart Card
Stopped Smart Card Removal Policy
Stopped SNMP Trap
Stopped Software Protection
Stopped SPP Notification Service
Stopped Tablet PC Input Service
Stopped Telephony
Stopped Thread Ordering Server
Stopped TPM Base Services
Stopped Virtual Disk
Stopped Volume Shadow Copy
Stopped WebClient
Stopped Windows Backup
Stopped Windows Biometric Service
Stopped Windows CardSpace
Stopped Windows Color System
Stopped Windows Connect Now - Config Registrar
Stopped Windows Driver Foundation - User-mode Driver Framework
Stopped Windows Error Reporting Service
Stopped Windows Event Collector
Stopped Windows Image Acquisition (WIA)
Stopped Windows Installer
Stopped Windows Media Center Receiver Service
Stopped Windows Media Center Scheduler Service
Stopped Windows Modules Installer
Stopped Windows Presentation Foundation Font Cache 3.0.0.0
Stopped Windows Remote Management (WS-Management)
Stopped Windows Time
Stopped WinHTTP Web Proxy Auto-Discovery Service
Stopped Wired AutoConfig
Stopped WLAN AutoConfig
Stopped WMI Performance Adapter
Stopped WWAN AutoConfig
TimeZone
TimeZone GMT +2:00 Hours
Language Romanian (Romania)
Location Romania
Format Romanian (Romania)
Currency lei
Date Format dd.MM.yyyy
Time Format HH:mm:ss
Scheduler
19.06.2017 00:26; GoogleUpdateTaskMachineUA
19.06.2017 16:26; GoogleUpdateTaskMachineCore
CCleanerSkipUAC
Hotfixes
Installed
18.06.2017 Microsoft .NET Framework 4 Client Profile for Windows 7 x86 (KB982670)
The Microsoft .NET Framework 4 Client Profile provides a subset
of features from the .NET Framework 4. The Client Profile is
designed to run client applications and to enable the fastest
possible deployment for Windows Presentation Foundation (WPF)
and Windows Forms technology.
17.06.2017 Windows Malicious Software Removal Tool - June 2017 (KB890830)
After the download, this tool runs one time to check your computer
for infection by specific, prevalent malicious software (including
Blaster, Sasser, and Mydoom) and helps remove any infection that
is found. If an infection is found, the tool will display a status
report the next time that you start your computer. A new version
of the tool will be offered every month. If you want to manually
run the tool on your computer, you can download a copy from the
Microsoft Download Center, or you can run an online version from
microsoft.com. This tool is not a replacement for an antivirus
product. To help protect your computer, you should use an antivirus
product.
17.06.2017 Windows 7 Service Pack 1 (KB976932)
Windows 7 Service Pack 1 is a recommended collection of updates
and improvements to Windows that are combined into a single installable
update. The service pack can help make your computer safer and
more reliable. A typical installation will take about 30 minutes
to complete, and you will have to restart your computer about
halfway through the process.
17.06.2017 Security Update for Windows 7 (KB2425227)
A security issue has been identified that could allow an attacker
to misrepresent a system action or behavior without the knowledge
of the user. You can help protect your system by installing this
update from Microsoft. After you install this update, you may
have to restart your system.
17.06.2017 Update for Windows 7 (KB3163589)
Install this update to resolve issues in Windows. For a complete
listing of the issues that are included in this update, see the
associated Microsoft Knowledge Base article for more information.
After you install this item, you may have to restart your computer.
17.06.2017 Security Update for Windows 7 (KB971468)
A security issue has been identified that could allow an unauthenticated
remote attacker to compromise your system and gain control over
it. You can help protect your system by installing this update
from Microsoft. After you install this update, you may have to
17.06.2017 Update for Windows 7 (KB2998812)
17.06.2017 Update for Windows 7 (KB3004469)
17.06.2017 Update for Windows 7 (KB3046480)
17.06.2017 Update for Windows 7 (KB3015428)
17.06.2017 Definition Update for Windows Defender - KB915597 (Definition 1.245.945.0)
Install this update to revise the definition files used to detect
spyware and other potentially unwanted software. Once you have
installed this item, it cannot be removed.
17.06.2017 Intel Corporation - Display - Intel(R) G33/G31 Express Chipset Family
Intel Corporation Display software update released in September,
2009
17.06.2017 Windows Update Agent 7.6.7600.256
The Windows Update Agent enables your computer to search for
and install updates from an update service. The agent can automatically
update itself as needed to communicate with the update service
when Windows searches for new updates.
Not Installed
System Folders
Application Data C:\ProgramData
Cookies C:\Users\HP\AppData\Roaming\Microsoft\Windows\Cookies
Desktop C:\Users\HP\Desktop
Documents C:\Users\Public\Documents
Fonts C:\Windows\Fonts
Global Favorites C:\Users\HP\Favorites
Internet History C:\Users\HP\AppData\Local\Microsoft\Windows\History
Local Application Data C:\Users\HP\AppData\Local
Music C:\Users\Public\Music
Path for burning CD C:\Users\HP\AppData\Local\Microsoft\Windows\Burn\Burn
Physical Desktop C:\Users\HP\Desktop
Pictures C:\Users\Public\Pictures
Program Files C:\Program Files
Public Desktop C:\Users\Public\Desktop
Start Menu C:\ProgramData\Microsoft\Windows\Start Menu
Start Menu Programs C:\ProgramData\Microsoft\Windows\Start Menu\Programs
Startup C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Templates C:\ProgramData\Microsoft\Windows\Templates
Temporary Internet Files C:\Users\HP\AppData\Local\Microsoft\Windows\Temporary Internet Files
User Favorites C:\Users\HP\Favorites
Videos C:\Users\Public\Videos
Windows Directory C:\Windows
Windows/System C:\Windows\system32
Process List
audiodg.exe
Process ID 11088
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 14 MB
Peak Memory Usage 14 MB
chrome.exe
Process ID 3708
User HP
Domain hp1
Path C:\Program Files\Google\Chrome\Application\chrome.exe
Memory Usage 179 MB
Peak Memory Usage 271 MB
chrome.exe
Process ID 1440
User HP
Domain hp1
Memory Usage 3.30 MB
Peak Memory Usage 3.94 MB
chrome.exe
Process ID 4060
User HP
Domain hp1
Memory Usage 3.19 MB
Peak Memory Usage 4.62 MB
chrome.exe
Process ID 3892
User HP
Domain hp1
Memory Usage 155 MB
Peak Memory Usage 214 MB
chrome.exe
Process ID 3856
User HP
Domain hp1
Memory Usage 35 MB
Peak Memory Usage 41 MB
chrome.exe
Process ID 1772
User HP
Domain hp1
Memory Usage 15 MB
Peak Memory Usage 30 MB
chrome.exe
Process ID 9172
User HP
Domain hp1
Memory Usage 31 MB
Peak Memory Usage 31 MB
chrome.exe
Process ID 8756
User HP
Domain hp1
Memory Usage 243 MB
Peak Memory Usage 453 MB
chrome.exe
Process ID 15336
User HP
Domain hp1
Memory Usage 92 MB
Peak Memory Usage 116 MB
csrss.exe
Process ID 356
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\csrss.exe
Memory Usage 2.37 MB
Peak Memory Usage 7.57 MB
csrss.exe
Process ID 416
User SYSTEM
Domain NT AUTHORITY
Memory Usage 2.52 MB
Peak Memory Usage 19 MB
csrss.exe
Process ID 3408
User SYSTEM
Domain NT AUTHORITY
Memory Usage 12 MB
Peak Memory Usage 17 MB
dwm.exe
Process ID 3824
User HP
Domain hp1
Path C:\Windows\system32\Dwm.exe
Memory Usage 77 MB
Peak Memory Usage 85 MB
dwm.exe
Process ID 1688
User Aurelian
Domain hp1
Memory Usage 1.78 MB
Peak Memory Usage 51 MB
explorer.exe
Process ID 372
User Aurelian
Domain hp1
Path C:\Windows\Explorer.EXE
Memory Usage 17 MB
Peak Memory Usage 33 MB
explorer.exe
Process ID 3876
User HP
Domain hp1
Memory Usage 43 MB
Peak Memory Usage 58 MB
flux.exe
Process ID 2072
User HP
Domain hp1
Path C:\Users\HP\AppData\Local\FluxSoftware\Flux\flux.exe
Memory Usage 7.25 MB
Peak Memory Usage 15 MB
GoogleCrashHandler.exe
Process ID 2212
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Google\Update\1.3.33.5\GoogleCrashHandler.exe
Memory Usage 532 KB
Peak Memory Usage 3.32 MB
lsass.exe
Process ID 520
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\lsass.exe
Memory Usage 6.19 MB
Peak Memory Usage 8.64 MB
lsm.exe
Process ID 528
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\lsm.exe
Memory Usage 2.34 MB
Peak Memory Usage 2.96 MB
mgabg.exe
Process ID 1576
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\mgabg.exe
Memory Usage 1.49 MB
Peak Memory Usage 2.07 MB
NvBackend.exe
Process ID 2328
User Aurelian
Domain hp1
Path C:\Program Files\NVIDIA Corporation\Update Core\NvBackend.exe
Memory Usage 4.78 MB
Peak Memory Usage 7.46 MB
NvBackend.exe
Process ID 4064
User HP
Domain hp1
Memory Usage 3.13 MB
Peak Memory Usage 4.51 MB
nvSCPAPISvr.exe
Process ID 732
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\NVIDIA Corporation\3D Vision\nvSCPAPISvr.exe
Memory Usage 2.89 MB
Peak Memory Usage 5.90 MB
nvvsvc.exe
Process ID 708
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\nvvsvc.exe
Memory Usage 3.22 MB
Peak Memory Usage 5.53 MB
pdesk.exe
Process ID 2344
User Aurelian
Domain hp1
Path C:\Windows\System32\PDesk\pdesk.exe
Memory Usage 2.55 MB
Peak Memory Usage 3.86 MB
pdesk.exe
Process ID 1444
User HP
Domain hp1
Memory Usage 2.50 MB
Peak Memory Usage 3.82 MB
S3Funkey.svc
Process ID 1608
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\s3graphics\chrome3\s3funkey.svc
Memory Usage 2.41 MB
Peak Memory Usage 2.80 MB
s3loadsv.svc
Process ID 1648
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\s3graphics\chrome3\s3loadsv.svc
Memory Usage 1.86 MB
Peak Memory Usage 2.67 MB
SearchIndexer.exe
Process ID 2664
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\SearchIndexer.exe
Memory Usage 12 MB
services.exe
Process ID 512
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\services.exe
Memory Usage 4.89 MB
Peak Memory Usage 8.97 MB
smss.exe
Process ID 256
User SYSTEM
Domain NT AUTHORITY
Path \SystemRoot\System32\smss.exe
Memory Usage 536 KB
Peak Memory Usage 836 KB
Speccy.exe
Process ID 19084
User HP
Domain hp1
Path C:\Program Files\Speccy\Speccy.exe
Memory Usage 19 MB
spoolsv.exe
Process ID 1352
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\spoolsv.exe
Memory Usage 5.48 MB
Peak Memory Usage 8.18 MB
svchost.exe
Process ID 1096
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Windows\system32\svchost.exe
Memory Usage 6.48 MB
Peak Memory Usage 11 MB
svchost.exe
Process ID 1188
User NETWORK SERVICE
Domain NT AUTHORITY
Memory Usage 7.73 MB
Peak Memory Usage 10 MB
svchost.exe
Process ID 1380
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 8.08 MB
Peak Memory Usage 12 MB
svchost.exe
Process ID 876
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Windows\System32\svchost.exe
Memory Usage 9.96 MB
svchost.exe
Process ID 2976
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 27 MB
Peak Memory Usage 50 MB
svchost.exe
Process ID 5556
User SYSTEM
Domain NT AUTHORITY
Memory Usage 28 MB
Peak Memory Usage 250 MB
svchost.exe
Process ID 3176
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 8.21 MB
Peak Memory Usage 9.54 MB
svchost.exe
Process ID 644
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.08 MB
Peak Memory Usage 6.58 MB
svchost.exe
Process ID 776
Domain NT AUTHORITY
Memory Usage 4.50 MB
Peak Memory Usage 5.06 MB
svchost.exe
Process ID 908
User SYSTEM
Domain NT AUTHORITY
Memory Usage 36 MB
Peak Memory Usage 38 MB
svchost.exe
Process ID 936
User SYSTEM
Domain NT AUTHORITY
Memory Usage 21 MB
Peak Memory Usage 24 MB
System
Process ID 4
Peak Memory Usage 6.47 MB
System Idle Process
Process ID 0
taskhost.exe
Process ID 3912
User HP
Domain hp1
Path C:\Windows\system32\taskhost.exe
Memory Usage 5.65 MB
Peak Memory Usage 5.66 MB
taskhost.exe
Process ID 1208
User Aurelian
Domain hp1
Memory Usage 4.19 MB
Peak Memory Usage 5.70 MB
wininit.exe
Process ID 408
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\wininit.exe
Memory Usage 2.48 MB
Peak Memory Usage 3.22 MB
winlogon.exe
Process ID 472
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\system32\winlogon.exe
Peak Memory Usage 6.16 MB
winlogon.exe
Process ID 3432
User SYSTEM
Domain NT AUTHORITY
Memory Usage 3.52 MB
WmiPrvSE.exe
Process ID 19448
Domain NT AUTHORITY
Path C:\Windows\system32\wbem\wmiprvse.exe
Memory Usage 8.91 MB
Peak Memory Usage 9.33 MB
WmiPrvSE.exe
Process ID 17564
User SYSTEM
Domain NT AUTHORITY
Memory Usage 4.65 MB
Peak Memory Usage 4.65 MB
wmpnetwk.exe
Process ID 2760
Domain NT AUTHORITY
Path C:\Program Files\Windows Media Player\wmpnetwk.exe
Memory Usage 6.98 MB
Peak Memory Usage 22 MB
wuauclt.exe
Process ID 3592
User HP
Domain hp1
Path C:\Windows\system32\wuauclt.exe
Memory Usage 3.65 MB
Peak Memory Usage 4.93 MB
Security Options
Accounts: Administrator account status Disabled
Accounts: Guest account status Disabled
Accounts: Limit local account use of blank passwords to console logon only Enabled
Accounts: Rename administrator account Administrator
Accounts: Rename guest account Guest
Audit: Audit the access of global system objects Disabled
Audit: Audit the use of Backup and Restore privilege Disabled
Audit: Force audit policy subcategory settings (Windows Vista or later) to override audit policy category settings Not Defined
Audit: Shut down system immediately if unable to log security audits Disabled
DCOM: Machine Access Restrictions in Security Descriptor Definition Language (SDDL) syntax Not Defined
DCOM: Machine Launch Restrictions in Security Descriptor Definition Language (SDDL) syntax Not Defined
Devices: Allow undock without having to log on Enabled
Devices: Allowed to format and eject removable media Not Defined
Devices: Prevent users from installing printer drivers Disabled
Devices: Restrict CD-ROM access to locally logged-on user only Not Defined
Devices: Restrict floppy access to locally logged-on user only Not Defined
Domain controller: Allow server operators to schedule tasks Not Defined
Domain controller: LDAP server signing requirements Not Defined
Domain controller: Refuse machine account password changes Not Defined
Domain member: Digitally encrypt or sign secure channel data (always) Enabled
Domain member: Digitally encrypt secure channel data (when possible) Enabled
Domain member: Digitally sign secure channel data (when possible) Enabled
Domain member: Disable machine account password changes Disabled
Domain member: Maximum machine account password age 30 days
Domain member: Require strong (Windows 2000 or later) session key Enabled
Interactive logon: Display user information when the session is locked Not Defined
Interactive logon: Do not display last user name Disabled
Interactive logon: Do not require CTRL+ALT+DEL Not Defined
Interactive logon: Message text for users attempting to log on
Interactive logon: Message title for users attempting to log on
Interactive logon: Number of previous logons to cache (in case domain controller is not available) 10 logons
Interactive logon: Prompt user to change password before expiration 5 days
Interactive logon: Require Domain Controller authentication to unlock workstation Disabled
Interactive logon: Require smart card Disabled
Interactive logon: Smart card removal behavior No Action
Microsoft network client: Digitally sign communications (always) Disabled
Microsoft network client: Digitally sign communications (if server agrees) Enabled
Microsoft network client: Send unencrypted password to third-party SMB servers Disabled
Microsoft network server: Amount of idle time required before suspending session 15 minutes
Microsoft network server: Digitally sign communications (always) Disabled
Microsoft network server: Digitally sign communications (if client agrees) Disabled
Microsoft network server: Disconnect clients when logon hours expire Enabled
Microsoft network server: Server SPN target name validation level Not Defined
Network access: Allow anonymous SID/Name translation Disabled
Network access: Do not allow anonymous enumeration of SAM accounts Enabled
Network access: Do not allow anonymous enumeration of SAM accounts and shares Disabled
Network access: Do not allow storage of passwords and credentials for network authentication Disabled
Network access: Let Everyone permissions apply to anonymous users Disabled
Network access: Named Pipes that can be accessed anonymously
Network access: Remotely accessible registry paths System\CurrentControlSet\Control\ProductOptions,System\CurrentControlSet\Control\Server Applications,Software\Microsoft\Windows NT\CurrentVersion
Network access: Remotely accessible registry paths and sub-paths System\CurrentControlSet\Control\Print\Printers,System\CurrentControlSet\Services\Eventlog,Software\Microsoft\OLAP Server,Software\Microsoft\Windows NT\CurrentVersion\Print,Software\Microsoft\Windows NT\CurrentVersion\Windows,System\CurrentControlSet\Control\ContentIndex,System\CurrentControlSet\Control\Terminal Server,System\CurrentControlSet\Control\Terminal Server\UserConfig,System\CurrentControlSet\Control\Terminal Server\DefaultUserConfiguration,Software\Microsoft\Windows NT\CurrentVersion\Perflib,System\CurrentControlSet\Services\SysmonLog
Network access: Restrict anonymous access to Named Pipes and Shares Enabled
Network access: Shares that can be accessed anonymously Not Defined
Network access: Sharing and security model for local accounts Classic - local users authenticate as themselves
Network security: Allow Local System to use computer identity for NTLM Not Defined
Network security: Allow LocalSystem NULL session fallback Not Defined
Network Security: Allow PKU2U authentication requests to this computer to use online identities Not Defined
Network security: Configure encryption types allowed for Kerberos Not Defined
Network security: Do not store LAN Manager hash value on next password change Enabled
Network security: Force logoff when logon hours expire Disabled
Network security: LAN Manager authentication level Not Defined
Network security: LDAP client signing requirements Negotiate signing
Network security: Minimum session security for NTLM SSP based (including secure RPC) clients Require 128-bit encryption
Network security: Minimum session security for NTLM SSP based (including secure RPC) servers Require 128-bit encryption
Network security: Restrict NTLM: Add remote server exceptions for NTLM authentication Not Defined
Network security: Restrict NTLM: Add server exceptions in this domain Not Defined
Network security: Restrict NTLM: Audit Incoming NTLM Traffic Not Defined
Network security: Restrict NTLM: Audit NTLM authentication in this domain Not Defined
Network security: Restrict NTLM: Incoming NTLM traffic Not Defined
Network security: Restrict NTLM: NTLM authentication in this domain Not Defined
Network security: Restrict NTLM: Outgoing NTLM traffic to remote servers Not Defined
Recovery console: Allow automatic administrative logon Disabled
Recovery console: Allow floppy copy and access to all drives and all folders Disabled
Shutdown: Allow system to be shut down without having to log on Enabled
Shutdown: Clear virtual memory pagefile Disabled
System cryptography: Force strong key protection for user keys stored on the computer Not Defined
System cryptography: Use FIPS compliant algorithms for encryption, hashing, and signing Disabled
System objects: Require case insensitivity for non-Windows subsystems Enabled
System objects: Strengthen default permissions of internal system objects (e.g. Symbolic Links) Enabled
System settings: Optional subsystems Posix
System settings: Use Certificate Rules on Windows Executables for Software Restriction Policies Disabled
User Account Control: Admin Approval Mode for the Built-in Administrator account Disabled
User Account Control: Allow UIAccess applications to prompt for elevation without using the secure desktop Disabled
User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode Prompt for consent for non-Windows binaries
User Account Control: Behavior of the elevation prompt for standard users Prompt for credentials
User Account Control: Detect application installations and prompt for elevation Enabled
User Account Control: Only elevate executables that are signed and validated Disabled
User Account Control: Only elevate UIAccess applications that are installed in secure locations Enabled
User Account Control: Run all administrators in Admin Approval Mode Enabled
User Account Control: Switch to the secure desktop when prompting for elevation Enabled
User Account Control: Virtualize file and registry write failures to per-user locations Enabled
Device Tree
ACPI x86-based PC
Microsoft ACPI-Compliant System
ACPI Fixed Feature Button
ACPI Power Button
Intel 82802 Firmware Hub Device
Intel Core2 Duo CPU E7400 @ 2.80GHz
System board
PCI bus
Intel 82801G (ICH7 Family) PCI Express Root Port - 27D0
Intel 82801G (ICH7 Family) SMBus Controller - 27DA
Intel G33/G31/P35/P31 Express Chipset Processor to I/O Controller - 29C0
Motherboard resources
Intel(R) G33/G31 Express Chipset Family (Microsoft Corporation - WDDM 1.0)
High Definition Audio Controller
Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D2
Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
USB Root Hub
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
USB Root Hub
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
USB Root Hub
USB Composite Device
USB Input Device
HID Keyboard Device
USB Input Device
HID-compliant consumer control device
HID-compliant device
Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
USB Root Hub
Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
USB Root Hub
Intel(R) 82801 PCI Bridge - 244E
PCI Serial Port
Intel(R) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8
Communications Port (COM1)
Direct memory access controller
High precision event timer
Numeric data processor
Programmable interrupt controller
PS/2 Compatible Mouse
Standard PS/2 Keyboard
System CMOS/real time clock
System speaker
System timer
Standard floppy disk controller
Floppy disk drive
Printer Port (LPT1)
Printer Port Logical Interface
Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
ATA Channel 1
ATA Channel 0
Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
ATA Channel 0
ATA Channel 1
CPU
Cores 2
Threads 2
Name Intel Core 2 Duo E7400
Code Name Wolfdale
Package Socket 775 LGA
Technology 45nm
Specification Intel Core2 Duo CPU E7400 @ 2.80GHz
Family 6
Extended Family 6
Model 7
Extended Model 17
Stepping A
Revision R0
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, Intel 64, NX
Virtualization Not supported
Hyperthreading Not supported
Fan Speed 941 RPM
Bus Speed 266.6 MHz
Rated Bus Speed 1066.6 MHz
Stock Core Speed 2800 MHz
Stock Bus Speed 266 MHz
Average Temperature 38 °C
Caches
L1 Data Cache Size 2 x 32 KBytes
L1 Instructions Cache Size 2 x 32 KBytes
L2 Unified Cache Size 3072 KBytes
Cores
Core 0
Core Speed 1999.8 MHz
Multiplier x 7.5
Bus Speed 266.6 MHz
Temperature 39 °C
Threads APIC ID: 0
Core 1
Multiplier x 7.5
Bus Speed 266.6 MHz
Temperature 36 °C
Threads APIC ID: 1
RAM
Memory slots
Total memory slots 2
Used memory slots 2
Free memory slots 0
Memory
Type DDR2
Size 2048 MBytes
Channels # Dual
DRAM Frequency 266.6 MHz
CAS# Latency (CL) 4 clocks
RAS# to CAS# Delay (tRCD) 4 clocks
RAS# Precharge (tRP) 4 clocks
Cycle Time (tRAS) 12 clocks
Command Rate (CR) 2T
Physical Memory
Memory Usage 61 %
Total Physical 1.99 GB
Available Physical 777 MB
Total Virtual 3.98 GB
Available Virtual 2.40 GB
SPD
Number Of SPD Modules 2
Slot #1
Type DDR2
Size 1024 MBytes
Manufacturer Kingston
Max Bandwidth PC2-6400 (400 MHz)
Part Number
Serial Number 1930823970
Week/year 32 / 09
Timing table
JEDEC #1
Frequency 266.7 MHz
CAS# Latency 4,0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1,800 V
JEDEC #2
Frequency 333.3 MHz
CAS# Latency 5,0
RAS# To CAS# 5
RAS# Precharge 5
tRAS 16
tRC 21
Voltage 1,800 V
JEDEC #3
Frequency 400.0 MHz
CAS# Latency 6,0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 18
tRC 24
Voltage 1,800 V
Slot #2
Type DDR2
Size 1024 MBytes
Max Bandwidth PC2-4300 (266 MHz)
Part Number
Serial Number 2369139757
Week/year 12 / 10
Timing table
JEDEC #1
Frequency 200.0 MHz
CAS# Latency 3,0
RAS# To CAS# 3
RAS# Precharge 3
tRAS 9
tRC 12
Voltage 1,800 V
JEDEC #2
Frequency 266.7 MHz
CAS# Latency 4,0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1,800 V
JEDEC #3
Frequency 266.7 MHz
CAS# Latency 5,0
RAS# To CAS# 4
RAS# Precharge 4
tRAS 12
tRC 16
Voltage 1,800 V
Motherboard
Manufacturer Gigabyte Technology Co. Ltd.
Model G31M-ES2L (Socket 775)
Version x.x
Chipset Vendor Intel
Chipset Model P35/G33/G31
Chipset Revision 10
Southbridge Vendor Intel
Southbridge Model 82801GB (ICH7/R)
Southbridge Revision A1
System Temperature 30 °C
BIOS
Brand Award Software International Inc.
Version FC
Date 02.07.2009
Voltage
CPU CORE 1.072 V
MEMORY CONTROLLER 1.920 V
+3.3V 3.296 V
+5V 4.892 V
+12V 1.344 V
-12V -8.128 V
+5V HIGH THRESHOLD 5.322 V
CMOS BATTERY 3.088 V
PCI Data
Slot PCI
Slot Type PCI
Slot Usage In Use
Bus Width 32 bit
Slot Designation PCI
Characteristics 5V, 3.3V, PME, SMBus
Slot Number 0
Slot PCI
Slot Type PCI
Slot Usage Available
Bus Width 32 bit
Slot Number 1
Slot PCI
Slot Type PCI
Slot Usage In Use
Bus Width 32 bit
Slot Number 2
Slot PCI
Slot Type PCI
Slot Usage In Use
Bus Width 32 bit
Slot Number 3
Graphics
Monitor
Name Generic Non-PnP Monitor on Intel G33/G31 Express Chipset Family (Microsoft Corporation - WDDM 1.0)
Current Resolution 1680x1050 pixels
Work Resolution 1680x1010 pixels
State Enabled, Primary, Output devices support
Monitor Width 1680
Monitor Height 1050
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Manufacturer Intel
Model G33/G31 Express Chipset Family
Device ID 8086-29C2
Revision 11
Subvendor Gigabyte (1458)
Current Performance Level Level 0
Driver version 8.15.10.1749
Count of performance levels : 1
Level 1 - "Perf Level 0"
Storage
Hard drives
Manufacturer Hitachi
Product Family Deskstar
Series Prefix Standard
Model Capacity For This Specific Drive 160GB
Heads 16
Cylinders 19.457
Tracks 4.961.535
Sectors 312.576.705
SATA type SATA-II 3.0Gb/s
Device type Fixed
ATA Standard ATA/ATAPI-7
Serial Number PVF904ZF0D7EZN
Firmware Version Number P22OABEA
LBA Size 48-bit LBA
Power On Count 6047 times
Power On Time 315,4 days
Features S.M.A.R.T., APM, AAM, NCQ
Max. Transfer Mode SATA II 3.0Gb/s
Used Transfer Mode SATA II 3.0Gb/s
Interface SATA
Capacity 149 GB
Real size 160.040.803.840 bytes
RAID Type None
S.M.A.R.T
Status Good
Temperature 33 °C
Temperature Range OK (less than 50 °C)
S.M.A.R.T attributes
01
Attribute name Read Error Rate
Real value 0
Current 100
Worst 100
Threshold 16
Raw Value 0000000000
Status Good
02
Attribute name Throughput Performance
Real value 0
Current 100
Worst 100
Threshold 50
Status Good
03
Attribute name Spin-Up Time
Real value 10092684 ms
Current 136
Worst 136
Threshold 24
Raw Value 00009A008C
Status Good
04
Attribute name Start/Stop Count
Real value 6.359
Current 99
Worst 99
Threshold 0
Raw Value 00000018D7
Status Good
05
Attribute name Reallocated Sectors Count
Real value 0
Current 100
Worst 100
Threshold 5
Status Good
07
Attribute name Seek Error Rate
Real value 0
Current 100
Worst 100
Threshold 67
Status Good
08
Attribute name Seek Time Performance
Real value 0
Current 100
Worst 100
Threshold 20
Status Good
09
Attribute name Power-On Hours (POH)
Real value 315d 9h
Current 99
Worst 99
Threshold 0
Raw Value 0000001D91
Status Good
0A
Attribute name Spin Retry Count
Real value 0
Current 100
Worst 100
Threshold 60
Status Good
0C
Attribute name Device Power Cycle Count
Real value 6.047
Current 99
Worst 99
Threshold 0
Raw Value 000000179F
Status Good
C0
Attribute name Power-off Retract Count
Real value 6.367
Current 95
Worst 95
Threshold 0
Raw Value 00000018DF
Status Good
C1
Attribute name Load/Unload Cycle Count
Real value 6.367
Current 95
Worst 95
Threshold 0
Status Good
C2
Attribute name Temperature
Real value 33 °C
Current 181
Worst 181
Threshold 0
Raw Value 0000000021
Status Good
C4
Attribute name Reallocation Event Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C5
Attribute name Current Pending Sector Count
Real value 1
Current 100
Worst 100
Threshold 0
Raw Value 0000000001
Status Good
C6
Attribute name Uncorrectable Sector Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Attribute name UltraDMA CRC Error Count
Real value 0
Current 200
Worst 253
Threshold 0
Status Good
Partition 0
Partition ID Disk #0, Partition #0
Disk Letter D:
File System NTFS
Volume Serial Number 7A917270
Size 149 GB
Used Space 94 MB (0%)
Free Space 148 GB (100%)
Manufacturer SAMSUNG
Business Unit/Brand Desktop
Model Capacity For This Specific Drive 1.6TB
Heads 16
Cylinders 19.457
Tracks 4.961.535
Sectors 312.576.705
Device type Fixed
Serial Number S0V3J90Q102432
Firmware Version Number JF100-19
LBA Size 48-bit LBA
Power On Count 2671 times
Power On Time 638,8 days
Interface SATA
Capacity 149 GB
RAID Type None
S.M.A.R.T
Status Good
Temperature 33 °C
01
Real value 0
Current 100
Worst 100
Threshold 51
Status Good
03
Real value 4352 ms
Current 253
Worst 253
Threshold 25
Raw Value 0000001100
Status Good
04
Real value 5.034
Current 96
Worst 96
Threshold 0
Raw Value 00000013AA
Status Good
05
Real value 0
Current 253
Worst 253
Threshold 10
Status Good
07
Real value 0
Current 253
Worst 253
Threshold 51
Status Good
08
Real value 0
Current 253
Worst 253
Threshold 15
Status Good
09
Real value 638d 19h
Current 100
Worst 100
Threshold 0
Raw Value 0000003BE3
Status Good
0A
Real value 0
Current 253
Worst 253
Threshold 51
Status Good
0B
Attribute name Recalibration Retries
Real value 0
Current 253
Worst 100
Threshold 0
Status Good
0C
Real value 2.671
Current 98
Worst 98
Threshold 0
Raw Value 0000000A6F
Status Good
0D
Attribute name Soft Read Error Rate
Real value 4.933.923
Current 100
Worst 100
Threshold 0
Raw Value 00004B4923
Status Good
B8
Attribute name End-to-End error / IOEDC
Real value 0
Current 253
Worst 253
Threshold 99
Status Good
BB
Attribute name Reported Uncorrectable Errors
Real value 0
Current 253
Worst 253
Threshold 0
Status Good
BC
Attribute name Command Timeout
Real value 0
Current 253
Worst 253
Threshold 0
Status Good
BE
Attribute name Airflow Temperature
Real value
Current 145
Worst 121
Threshold 0
Raw Value 002704001F
Status Good
C2
Real value 32 °C
Current 142
Worst 121
Threshold 0
Raw Value 0027040020
Status Good
C3
Attribute name ECC Rate
Current 100
Worst 100
Threshold 0
Status Good
C4
Real value 0
Current 253
Worst 253
Threshold 0
Status Good
C5
Real value 0
Current 253
Worst 253
Threshold 0
Status Good
C6
Real value 0
Current 253
Worst 253
Threshold 0
Status Good
C7
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C8
Attribute name Write Error Rate / Multi-Zone Error Rate
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C9
Real value 0
Current 253
Worst 100
Threshold 0
Status Good
CA
Attribute name Data Address Mark errors
Real value 0
Current 253
Worst 253
Threshold 0
Status Good
Partition 0
Partition ID Disk #1, Partition #0
Disk Letter C:
File System NTFS
Volume Serial Number 4C896503
Size 149 GB
Used Space 39,8 GB (26%)
Free Space 109 GB (74%)
Optical Drives
Media Type DVD Writer
Name Optiarc DVD RW AD-5200A ATA Device
Availability Running/Full Power
Capabilities Random Access, Supports Writing, Supports Removable Media
Read capabilities CD-R, CD-RW, CD-ROM, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-R DL, DVD+R DL
Write capabilities CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-R DL, DVD+R DL
Config Manager Error Code Device is working properly
Config Manager User Config FALSE
Drive E:
Media Loaded FALSE
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 0
SCSI Target Id 0
Status OK
Audio
Sound Card
Playback Device
Digital Audio (S/PDIF) (High Definition Audio Device)
Peripherals
HID Keyboard Device
Device Kind Keyboard
Device Name HID Keyboard Device
Vendor Microsoft
Location USB Input Device
Driver
Date 6-21-2006
Version 6.1.7600.16385
File C:\Windows\system32\DRIVERS\kbdhid.sys
File C:\Windows\system32\DRIVERS\kbdclass.sys
Device Name Standard PS/2 Keyboard
Vendor (Standard keyboards)
Location plugged into keyboard port
Driver
Date 6-21-2006
File C:\Windows\system32\DRIVERS\i8042prt.sys
Device Kind Mouse
Device Name PS/2 Compatible Mouse
Vendor Microsoft
Location plugged into PS/2 mouse port
Driver
Date 6-21-2006
File C:\Windows\system32\DRIVERS\mouclass.sys
Printers
Fax
Printer Port SHRFAX:
Print Processor winprint
Availability Always
Priority 1
Duplex None
Print Quality 200 * 200 dpi Monochrome
Status Unknown
Driver
Driver Name Microsoft Shared Fax Driver (v4.00)
Driver Path C:\Windows\system32\spool\DRIVERS\W32X86\3\FXSDRV.DLL
Microsoft XPS Document Writer (Default Printer)
Printer Port XPSPort:
Availability Always
Priority 1
Duplex None
Print Quality 600 * 600 dpi Color
Status Unknown
Driver
Driver Name Microsoft XPS Document Writer (v6.00)
Driver Path C:\Windows\system32\spool\DRIVERS\W32X86\3\mxdwdrv.dll
Network
You are connected to the internet
Connected through Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
IP Address 192.168.0.100
Subnet mask 255.255.255.0
Gateway server 192.168.0.1
Preferred DNS server 192.168.0.1
DHCP Enabled
DHCP server 192.168.0.1
External IP Address 46.108.111.155
Adapter Type Ethernet
NetBIOS over TCP/IP Enabled via DHCP
NETBIOS Node Type Hybrid node
Link Speed 25.9 KBps
Computer Name
NetBIOS Name HP1
DNS Name hp1
Membership Part of workgroup
Workgroup WORKGROUP
Remote Desktop
Disabled
Console
State Active
Domain hp1
WinInet Info
LAN Connection
Local system uses a local area network to connect to the Internet
Local system has RAS to connect to the Internet
Wi-Fi Info
Wi-Fi not enabled
WinHTTPInfo
WinHTTPSessionProxyType No proxy
Session Proxy
Session Proxy Bypass
Connect Retries 5
Connect Timeout (ms) 60.000
HTTP Version HTTP 1.1
Max Connects Per 1.0 Servers INFINITE
Max Connects Per Servers INFINITE
Max HTTP automatic redirects 10
Max HTTP status continue 10
Send Timeout (ms) 30.000
IEProxy Auto Detect No
IEProxy Auto Config
IEProxy
IEProxy Bypass
Default Proxy Config Access Type No proxy
Default Config Proxy
Default Config Proxy Bypass
Sharing and Discovery
Network Discovery Enabled
File and Printer Sharing Enabled
File and printer sharing service Enabled
Simple File Sharing Enabled
Administrative Shares Enabled
Adapters List
Enabled
Connection Name Local Area Connection
NetBIOS over TCPIP Yes
DHCP enabled Yes
MAC Address 00-24-1D-C3-C8-4B
DHCP 192.168.0.1
DNS Server 192.168.0.1
Network Shares
Users C:\Users
Current TCP Connections
C:\Program Files\Google\Chrome\Application\chrome.exe (3708)
Local 192.168.0.100:49171 ESTABLISHED Remote 74.125.71.188:5228 (Querying... )
Local 192.168.0.100:49622 ESTABLISHED Remote 185.60.218.19:443 (Querying... ) (HTTPS)
Local 192.168.0.100:49805 ESTABLISHED Remote 151.101.12.64:80 (Querying... ) (HTTP)
Local 192.168.0.100:49806 ESTABLISHED Remote 151.101.12.64:80 (Querying... ) (HTTP)
C:\Program Files\NVIDIA Corporation\Update Core\NvBackend.exe (4064)
Local 127.0.0.1:23402 LISTEN
lsass.exe (520)
Local 0.0.0.0:49156 LISTEN
NvBackend.exe (2328)
Local 127.0.0.1:23401 LISTEN
services.exe (512)
Local 0.0.0.0:49155 LISTEN
svchost.exe (776)
Local 0.0.0.0:135 (DCE) LISTEN
svchost.exe (876)
Local 0.0.0.0:49153 LISTEN
svchost.exe (936)
Local 0.0.0.0:49154 LISTEN
System Process
Local 192.168.0.100:49763 TIME-WAIT Remote 68.232.34.81:80 (Querying... ) (HTTP)
Local 192.168.0.100:49787 TIME-WAIT Remote 104.237.191.1:443 (Querying... ) (HTTPS)
Local 192.168.0.100:49793 TIME-WAIT Remote 77.232.217.115:80 (Querying... ) (HTTP)
Local 192.168.0.100:49794 TIME-WAIT Remote 172.217.23.174:443 (Querying... ) (HTTPS)
Local 192.168.0.100:49795 TIME-WAIT Remote 216.58.206.14:443 (Querying... ) (HTTPS)
System Process
Local 0.0.0.0:445 (Windows shares) LISTEN
Local 0.0.0.0:2869 LISTEN
Local 0.0.0.0:5357 LISTEN
Local 0.0.0.0:10243 LISTEN
Local 192.168.0.100:139 (NetBIOS session service) LISTEN
wininit.exe (408)
Local 0.0.0.0:49152 LISTEN
wmpnetwk.exe (2760)
Local 0.0.0.0:554 LISTEN
Generated with Speccy v1.30.730
There should be everything you need .
Will these be compatible with my motherboard ?
