Best Graphics Card for my AWARDACPI?
sachinnevercry
12
Which Graphics Card support my AWRDACPI motherboard?
Machine name: HOME-2FA5D07641
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: INTELR
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Pentium(R) D CPU 3.00GHz (2 CPUs)
Memory: 2040MB RAM
Page File: 659MB used, 3271MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: None
DxDiag Version: 5.03.2600.2180 32bit Unicode
4000 isn't a lot to work with, and you've got a pretty old machine there too. Do you per chance know your motherboard make and model #? You're running the LGA 775 platform, which means you might have a board that's limited to AGP graphics, not PCI Express.
Hi I've only PCI slots in my MOBO.
Memory: 2040MB RAM
Memory: 2040MB RAM
Yes, we saw that above. That's your OS system properties. We need the actual model number of your motherboard. To get that, you'll have to look inside your computer and see what's printed on it. Or go into your BIOS setup and see what's listed there.
Hi I've seen my MOBO found no AGP slot in MOBO but there was pin holes available there.
Now can you suggest me according to MOBO printed AGP8x can it be soldering on MOBO if yes where I can get the AGP8x slot.
