Best Graphics Card Under 10.20" Maximum Length
if you actually have 10.2 inches then you have tons of room to work with on just about any card out there. I wonder is that measurement right though? seems fairly long for mini itx because the cards Scremin34Egl is talking about are right under 7" and msi designed them specifically for shorter mini itx cases / mbs. I have the 270x msi mini itx and love it, it's so fast and runs super cool even with one fan. I would hit something after 8.2" on my mb so needed a shorter one. Almost all of the 270x / 280x and gtx 760 / 770 cards have dual fan models within the measurements you need. I would check closer though because that does seem long for what your doing, make sure there is nowhere you will hit on the mb. In my case the heatsinks of...
if you actually have 10.2 inches then you have tons of room to work with on just about any card out there. I wonder is that measurement right though? seems fairly long for mini itx because the cards Scremin34Egl is talking about are right under 7" and msi designed them specifically for shorter mini itx cases / mbs. I have the 270x msi mini itx and love it, it's so fast and runs super cool even with one fan. I would hit something after 8.2" on my mb so needed a shorter one. Almost all of the 270x / 280x and gtx 760 / 770 cards have dual fan models within the measurements you need. I would check closer though because that does seem long for what your doing, make sure there is nowhere you will hit on the mb. In my case the heatsinks of the dual fan cards would touch the connector from the mb to my power button so even though I could of fit a 10+" card the mb forced shorter. I would highly recommend the msi posted above and it is under 200$. If you can fit / afford it though I would get the 280x. I love the 270x and it runs everything so far in high / ultra settings but I would of got the 280x had I been able to fit it b/c the performance is so much better and can handle higher resolutions and future games a bit better.
