I have a Dell factory installed power supply and I'm looking to upgrade my graphics card. What is the best nVidia graphics card I can get with this current power supply? I was looking at the GTX 560.
I input your system specifications in this: http://extreme.outervision.com/PSUEngine
and put 560 ti because it seems you are inclined with it. The recommended PSU wattage is 368w. So it looks like you can given that you got the 2x6PIN connector in your PSU. I would say it is a bit pushing it but I think it is okay.
Try the calculator yourself with other options to get the graphics card that will match both your need & budget within your PSU cap.
It actually depends on what are currently running on your PC?
motherboard?
processor?
RAM?
Hard disks?
Optical drive?
fans?
The 560 itself requires 150W or under normal assumptions a minimum of 450W PSU with 2x6pin PCIe connector. Capacity wise, your PSU can handle but does it have the 2x6PIN connector?
Hope that's everything you need. It's all Dell factory installed except the extra 8gb of Ram.
@_zxzxzx_ The specs on the nVidia site say that the 560Ti requires 500W minimum (http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-560ti/specifications). Mine looks like it says 460W max? Or I am I not looking in the right place? The GTX 560 (not Ti) says 450W though (http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-560/specifications).
A 560 will shorten the life of that power supply, it should work for a while, if you're overclocking it will be even more taxing. I'd think the easier answer would be to just spend $100 and get a better Power Supply.
I have the 2x6 pin connectors.
What's listed there is the recommended wattage. A good 450w PSU will run it fine because it's about the Amps that it can supply and not really the rated wattage. And yes, a good idea would be the HD 7850.
@psirohi @_zxzxzx_ The problem with the HD 7850 (and AMD cards in general) is that I have had so many issues running them with Maya. I use Maya for work (I'm a 3D artist) and I've tried a few AMD cards in the past few months, all of them have had showstopping problems (not being able to select objects, freezing regularly when snapping verts, graphical glitches when performing certain actions). I realise I should be using a workstation card but my funds don't stretch that far. And standard desktop nVidia cards always worked fine at the company I used to work for.
