Best high static pressure fans
Avillius
23
I've been looking into buying the NZXT Kraken X62 AIO cooler, and heard that fans with a high static pressure work better for radiators than standard "high airflow" fans. Upon hearing this, I wanted to know some good options for 140mm fans that have the trait.
The X62 is a high quality unit, and the fans that come with it are more than up to the job.
I seriously doubt you would get much more actual cooling performance by swapping fans.
You "might" get equal cooling with less noise. Maybe.
