dannyaa
594
I read all these posts about ABIT boards running too hot and I've gotten some suggestions for cooling things on my Antec Sonata Quiet case... but I think I'm gonna need a new heatsink. I have temp monitoring software and many times I idle at 40 but under load things quickly get to 65 and many times the comp just stops, turns black and everything locks up... I need lower temps.
So I am going to put a new fan in the case, but also I wanted to know what is the best $40-ish heatsink/fan that I can get to make my processor cool?
I have a P4c Northwood 3.2 and ABIT AI7 mobo. Thanks and MERRY CHRISTMAS!!
Dan
P4c 3.2Ghz @ 800MHz Northwood / ABIT AI7 / 1GB Corsair XMS-Pro CL2 Pc3200 / 160GB Seagate SATA 7200rpm 8mb cache / BFG-Tech Nvidia GeForce 6800GT 256mb / Antec Sonata case w/Antec TruePower 380W PSU
Aidanoridania
59
what about that new zalman 7700 CU ???
it is a tad mor expensive but then the quietness is there too then you got two in one :)
<font color=purple><i> Enosi and I.... </i></font color=purple>
dannyaa
594
great thanks for those suggestions! I've read up on both of those and I was a bit confused. One of the reviews I read (http://www.hardcoreware.net/reviews/review-253-3.htm) showed that the Zalman runs HOTTER than a stock heatsink... but quieter? Am I reading this wrong or is that the case? I can live with a little noise I just want to get the processor as cool as possible, do you think the Gigabyte Rocket cooler would be best for that? I am also looking at getting some Artic Silver 5 thermal compound... do you guys recommend that?
Thanks again!
endyen
Splendid
The new zalman comes with fan control. It is only hotter than the stock fan, at slowest speed setting. Even at fastest speed, it is quieter than the stock fan, and ofcourse, it keeps the chip cooler. You could do almost as well with a straight 7000 al-cu unit.
Cybercraig
2,058
You might need some extra fan power in that case. That seems too hot for a stock 3.2C under load. The stock copper-plate cooler is not that bad.
Abit IS7 - 3.0C @ 3.6ghz - Mushkin PC4000 (2 X 512) - Sapphire 9800Pro - TT 420 watt Pure Power
Samsung 120gb ATA-100 - Maxtor 40gb ATA - 100
Sony DRU-510A - Yellowtail Merlot
dannyaa
594
Alright, I am going to go ahead and pick up an Antec 120mm SmartCool fan unit... unless anyone recommends something different instead?
I think I am going to go with the Gigabyte 3D Rocket Pro GH-PCU22-VG
And also - should I pick up some Artic Silver 5 thermal compound? Anything I should know about applying this since I originally applied the stock intel thermal compound?
Thanks all!
