Best inexpensive Laser Printer?
G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
Anyone have a favorite Laser Printer, preferably in the $100 range?
Thanks,
Larry
I didn't know they made a $100 laser printer. I'd look at the inexpensive
Brothers (around $200, maybe less).
Sheldon
sheldon@sopris.net
"Larry Fieman" <_antispam_fieman@comcast.net> wrote in message
news:7Xaec.111049$gA5.1447894@attbi_s03...
> Thanks,
> Larry
One of the Samsungs gets rebated to under $100 occasionally. As with
many printers, it comes with a "starter" toner cartridge that has about
1/3 as much as the refill.
I just bought a Brothers HL-1440 from local Office Deport for around $100
after instant and mail-in rebate. I don't use the printer itself but
because it uses the same DRUM and Toner cartridge with my older Multiple
Functions laser printer (Printer, Scanner, Fax) with the drum life just
reached 20,000 pages and need to be replaced. So I bought the printer just
to get the drum and toner cartridge.
> Sheldon
> sheldon@sopris.net
> > Thanks,
> > Larry
"Larry Fieman" <_antispam_fieman@comcast.net> wrote in message news:<7Xaec.111049$gA5.1447894@attbi_s03>...
A used HP4 or 5 or 6. (Not the 5L or 6L though.)
Toner refills are cheap.
"Sheldon" (sheldon@REMOVEsopris.net) writes:
> Sheldon
> sheldon@sopris.net
I paid $100 (after rebate) for my Lexmark E310 (made by Samsung).
Samsung has offered a successor model for $100 (after rebate).
Conclusion: $100 is a price point, as long as you are willing to
file a rebate and put up with the aggrevation.
You'll have to read ads or web sites for prices with rebates.
I bought my Lexmark at Staples, but I think the $100 Samsung
price is most common at Micro Center.
Brendan
>> Thanks,
>> Larry
On Sun, 11 Apr 2004 22:33:27 GMT, "Sheldon" <sheldon@REMOVEsopris.net> wrote:
Limited Drum life, go for a Cheap HP I see they sell here for some $300nz so
in the US would be around $120us..
At least with a HP you away's get a new Drum..
>Sheldon
>sheldon@sopris.net
>> Thanks,
>> Larry
Life is not measured by the number of breaths we take, but by the moments that take our breath away. (George Carlin)
On Sun, 11 Apr 2004 12:34:11 GMT, "Larry Fieman"
>Thanks,
>Larry
Canon or HP..
As you get a new Drum..
HP or Canon..
"Alan" <7ibehx001@sneakemail.com> wrote in message
news:2a7ef8ef.0404120012.41ecbb09@posting.google.com...
Just curious, why not 5L or 6L?
"Jimmy" <whoknows@whocares.com> wrote in message news:<w5Hec.605$2e6.1@lakeread01>...
They're the ones where you stack the paper almost vertically and it's
supposed to slide into the printer. Unfortunately these are very prone
to jamming, grabbing 10 or more pages at a time. Generally I'd avoid
any printers with similar feeds, a paper tray at the bottom is much
preferable. Also it seems better at keeping dust, bugs and whatever
else you have wafting around falling into the works.
Especially for a used printer, you really want to see it print at
least 10 pages before buying. Low quality print may be due to an old
toner cart, so don't be too quick to dismiss on that ground, but paper
jamming quickly becomes a hair-tearing frustration.
I bought the Brother 1440L after I upgraded to XP sometime last year because
my Canon LBP465 was not XP-compatible though it was still working fine after
several years of use. But this Brother is the trickiest, touchiest printer
I have ever owned -- it frequently has to be cajoled into printing (turning
on and off, disconnecting printer cable, prerssing button, etc. etc.) One
of these days I'm going to get fed up with it and buy a new one even though
I'd like to get my money's worth out of it.
At the risk of being flamed, I have a Samsung 1710 that I got after instant
and mail in rebates for under $100. Yes it has the started cartridge so be
prepared after the second ream of paper to replace/refill it but it is
actually a great little printer for my needs. Yes it is noisy and no there
is not a low toner alert but for $100 it does everything expected of it.
> Thanks,
> Larry
I have to add this to what I said before. I had written Brother a
blow-off-steam letter complaining along the lines in my previous message,
and would you believe they just called me, apologized, and are going to send
me a replacement printer?
They had a record of my previous calls so they know I had problems. I am
absolutely amazed. There may be a problem with this particular printer.
Great company. Hope by next week I will be able to say it's a good printer.
They are a low end budget model..
I just picked up a 6L for say $25 us from a second hand shop that did no
really know what it was..
Then I imported a 8meg Ram module from MemoryX
But that was the dear part $55us, but as you pay here some $200-350nz for a
4meg HP one that is good, 8meg ones are not sold here.
That problem is old hat and was Fixed..
If you are buying a laser printer..Buy HP. I have been repairing laser
printer for 13 years. If I had to make a living on only repairing Hp laser
printers..I would starve. Its all the other brands I make my big bucks on.
Also the toner and drums are so much cheaper for HP than the other brands.
When you buy a laser printer consider recurring costs. Pete
> Thanks,
> Larry
On Tue, 13 Apr 2004 23:50:34 GMT, "Pete" <ppremock1@stny.rr.com>
HP are good. But, if you want to keep costs down a Kyocera is much
better (and just as reliable).
Hecate
Hecate@newsguy.com
veni, vidi, reliqui
Latest posts
