Best intel motherboard for 100 dollars or less
A few things...
MEM - The Z97 chipset is fine with DDR3-1866. Just don't go over 1.5v or a latency of CL10. The modules below are low latency (high performance) being DDR3-1866 CL9. Nicely priced today...
CASE - On a budget I like the Deepcool cases better.
PSU - No. XFX, Seasonic, the EVGA G2 lineup, or filter through the Tier 1 or Tier 2 list. The EVGA B1 model you listed is a Tier 3 unit and OK at best. www.tomshardware.com/forum/id-2547993/psu-tier-list.html
PCPartPicker part list / Price breakdown by merchant...
Decent choice. I have built a few systems lately that use Asrock boards, and all have been running with no problems. I like the BIOS interface as well.
The Extreme 4 series of boards offer a lot of features for the money. Do be careful when installing it as these boards seem to be a little thinner than most and flex easily. Once in the system and posting, you should have no problems.
Newf
Since you want SLI options to stay open, you will need a Z97 motherboard. Skip the older Z87 chipset... Look toward one of the boards in the link below.
https://pcpartpicker.com/parts/compare/asrock-motherboard-z97extreme4%2Casus-motherboard-z97eusb31%2Cgigabyte-motherboard-gaz97xsli%2Cmsi-motherboard-z97sslikraitedition/
If you want to skip the SLI option...
https://pcpartpicker.com/parts/compare/asrock-motherboard-h97anniversary%2Casrock-motherboard-h97pro4%2Casus-motherboard-h97plus%2Cgigabyte-motherboard-gah97d3h/
Awesome :) so this is my build so far, how does it look? http://pcpartpicker.com/p/MK2x3C
Im going to add an hdd in 2 weeks after the parts get here and ill also add a gtx 970 at that point as well
A few things...
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($175.88 @ OutletPC)
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard ($111.98 @ Newegg)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($42.75 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($88.89 @ OutletPC)
Case: Deepcool KENDOMEN Red ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($55.99 @ SuperBiiz)
Operating System: Microsoft Windows 7 Home Premium SP1 OEM (64-bit) ($88.99 @ NCIX US)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($17.75 @ OutletPC)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($29.99 @ Directron)
Total: $662.21
Huh well then. Thank you 😛 you did so much more than i asked for! Thanks, i appreciate it. I actually really like that case, is it bigger than the spec-01 and does it come with more than 1 fan, unlike the spec-01?
