Best Isopropyl Alcohol for cleaning CPU and GPU dies
The common 70% rubbing alcohol would work just as well, the aromatic additives are safe for just about any surface and sublimate quickly to leave nothing behind.
The main reasons to use high-alcohol for cleaning are:
- dries up quickly
- alcohol and distilled water are non-conductive
- no minerals or other contaminants to cause corrosion and stains
- alcohol and water mix can lift/dissolve a wider range of contaminants than either one alone
InvalidError
- dries up quickly
