Question Best Laptop for less than £1000
In order to understand if what you're looking at is what's necessary, we're going to need you to fill out answers for questions found in this thread. The answer will help the community narrow down the sort of laptop you need with respect to your task, budget and availability.
We can move forward from there.
If it's for gaming, I think you can do better for closer to 1000UKpounds. If it's with portability in mind and you don't do gaming but productivity, you could go for something lighter and cheaper.
Is the OLED screen important to you?
If yes there isnt really anything better
Maybe the pro 14 if you are fine with a 14" screen since it has same specs but 2.8k 90hz screen and is usually same price (just make sure its the 3050 version not just vega apu)
If you want to do gaming try to fit anything with an rtx 3060 usually the cheapest is the nitro 5
https://www.amazon.co.uk/Acer-Nitro...sprefix=acer+nitro+5+rtx+3060,aps,1226&sr=8-2
