Best laptop for work emails and excel
Eleni123
7
Hi I am looking for a laptop to do my emails and use excel and Microsoft and sort invoice files. Can anyone one reccomend one that's not slow and suitable for this I have a budget or up to £250/£300? Thanks in advance
The HP stream has only 2GB of RAM which is tolerable but on the slow side. It also only has a 32GB storage disk but it is a Solid State Drive which means it doesn't have a spinning disk running at 5,400 rpm all the time the machine is switched. You would definitely need external storage for that one.
The 14 refers to the diagonal measurement of the screen so 14". Most laptops start at 15.6" and netbooks have a 10" screen so you have an idea as to scale..
Staples has an Acer and a Toshiba around that price range. Both are more than adequate for your purpose. Money saving tip: Libre Office is free and MS OFfice is expnensive. The former is every bit as good as the dearer one and can display and edit documents, spreadsheets and presentations you may already made on the MS software..
Thank you so much ! I have been looking at an acer es15 do you know if it's any good and would I need a lot of strorage?
In my repair business, all the Acers I've had in during the last ten months have been for Windows related problems or upgrades. My wife runs an Acer laptop and it hasn't had any problems. That's all I can say. As to storage, at 1TB of disk space, it's a little over the top. You cold go for a less expensive model which has, say, 500GB or half the capacity of the ES15. You can buy external storage and indeed should do for regular backups so very few folks need a TB of storage.
Thank you sorry I'm probably really annoying but would you say the HP Stream 14-Ax002na, the HP 15-Ay082na, Intel® Celeron® N3060 Processor, or the HP Stream 14-ax054sa 14" Laptop may Be better? As you can see I have no idea about laptops just want something speedy and reliable if possible . Tia
If you can stretch your budget a bit I can personally recommend the LENOVO IdeaPad 310, which can be had for £350. I think it's worth the extra for two reasons.
The full HD screen is nicer to work with (most cheap laptops have a lower resolution), it's still quite wishy washy but I do a bit of light dev work on one and appreciate the higher resolution.
Secondly, the memory and hard drive are very easy to upgrade which isn't always the case with low specification machines. The default machine came with 4gb of RAM which I upgraded to 12gb in about 5 minutes flat. My previous computer was an Acer and upgrading memory and HDD involved removing the keyboard to get at the motherboard. It isn't a problem for me but many people wouldn't be happy to do this themselves.
Okay thank you been very helpful
Really, thank you I will take a look
I'm sorry but I can not agree with the above statement. Ssds are so much faster at loading programs and and opening files. Each email is essentially a file that needs to be opened … further complicated by often having attachments (pdfs, jpegs, word files, etc. etc.) embedded in the email. These attachments need to be opened by another program (word, paint, etc.) that needs to load and access the attachment file. Who of us hasn’t spent annoyingly long periods of time watching the ‘little circle spin’ while this is done? This is exactly what ssds are sooooo much better at … click on the attachment and ‘bang’ … there it is. This quote from Office Watch (I note that this would apply to any email reading program … not just ‘Outlook):
“Office benefits
Outlook is the main beneficiary of a solid state drive. That’s to be expected since Outlook is really a large database application which runs better if it can get information from the hard drive faster.”
Thinking about Excel ... (apart from just loading in a flash) ... it would also benifit from a ssd. For sure, it would not give any benefit to simply entering data but as soon as you actually used the data … the benefit would be noticed. For excel to do anything … it has to load the appropriate module to do the task (even something as simple as a graph)… again this is something a ssd speeds up hugely. So this quote from somewhere?:
“Office work usually (depending on what you do and what software you use) needs a moderate to high amount of memory, moderate CPU, and fast sequential and random access reads on your disk (SSDs, even cheap ones, are typically excellent at this). The most important "feature" of office programs is that they are ugly fat pigs which are already heavy on their own, and load a lot of small plugins, addons, templates, and whatnot all the time. Loading can literally take minutes if your disk drive can't cope. Write speed usually does not matter at all. You don't save once every two seconds, and it is usually a very quick process, too.
→ SSD model definitively preferrable.”
And this quote from ‘Office Watch’:
"For Word, Excel and PowerPoint we definitely noticed a vast speed up in Windows Explorer display including Open and Save dialogs in Office. Instead of waiting for files and folders to appear, a file list appears in a flash – just like it’s supposed to . Navigating around folders is much faster and easier. This SSD advantage is worth the extra price in our view.
Of course there are also the general advantages of a Solid State Drive. Windows startup is faster and transition to/from hibernation or sleep modes is a lot faster with SSD.”
Thanks do you can you reccomend an ssd laptop in my price range?
Also ... there is a bit of problem about Excel. There is using Excel and then there is USING EXCEL. It is a very sophisticated program which actually supports it's own programming language and very, very complex macros. I had a friend who used to use it to program games - strange as that may sound! It can also be used for very sophisticated statistical analysis (ANOVA, Analysis of Covariance, Multiple Regression, etc. etc). Needless to say ... to use excel for those types of things has different optimal system requirements than to use it to do more straightforward tasks like adding columns of numbers, finding averages etc.. What level of excel do you expect to be using ... more kinda like bookkeeping type tasks?
