Best Liquid Cooling System?
CCapG
48
Greetings:
I just have a quick question about the usage of liquid cooling on both my Video Card and my Processor.
My processor is an AMD-9590 and my Video Card is a Radeon R9 290X, a top of the line AMD Build. Yet I have only liquid cooled my CPU before, never have I found it necessary to cool both but I think it's time that I finally catch up and O/C both parts. In order to liquid cool both of them, what would I have to do? I am interested in the H100i but as far as I know, that only covers the processor, not the motherboard.
Any help you could give me would be great.
Thanks
There is absolutely no need to cover the motherboard, it does not help overclocking significantly to justify for the price. For the GPU cooler, get the NZXT Kraken G10 adapter and NZXT Kraken x40 or x60 if your case allows.
Hmm,you answered the question of cooling my GPU but how would you cool both the processor & GPU simultaneously?
Thanks
Then you need a custom loop. What case do you have? I'll configure a system for you. I also need to know your GPU Model (EXACT eg. with brand, model number, etc.)
What parts are you using in this build? As a reference, this would be great help to me.
The fittings and reservoir are made by bitspower, the fans are made by corsair the AF for the case and SP for the radiators, the radiator is alpha cool monstra, the pump is a swift tech 655 or a D5, the tubing is norprene 3/8 ID 5/8 OD, the CPU block is made by XSPC and the video card block is made by swift tech.
