Best liquid cooling system
Built your own with Innovatek parts they also have complete sets but they are expensive
or a Complete set Thermaltake Aquarius III but its external
<A HREF="http://www.freewebs.com/lb19984/" target="_new">My Rig</A>
Asetek KT12-L30A is the best beginners kit, and has fantastic cooling performance., have a look here:
<A HREF="http://www.waterchill.com/" target="_new">http://www.waterchill.com/</A>
In the UK you can buy em here:
<A HREF="http://www.overclockers.co.uk" target="_new">http://www.overclockers.co.uk</A>
or the TEC breaks and becomes one big resistor and melts you CPU / Mobo.
Also, the Electricity bill is going to go through the roof.
_______________________
<A HREF="http://www.moviewavs.com/MP3S/TV_Shows/Simpsons/flanderssong.mp3" target="_new">Audio Sig</A>
They only thing that needs power is the pump and the fans. The fans wont take more than 10watts even if you are using 2x120mm ones. I have no idea what a good pump would pull. With the asetek kits the pump is powered from an external source and so doesnt put any load on your PSU.
I was talking about the TEC.
Water cooling systems don't require much juice, the pump will be the biggest power drain, but usualy you connect these straight to a mains socket - not the PSU
I guess no one like my suggestion of the
Innovatek or the Thermaltake Aquarius III
well u know what you probably wont like my suggestion of the zalman reserator either
Oh well
Innovatek = Good performance
Zalman reserator = VERY quiet + reasonable performance
Thermaltake Aquarius III = If its anything like the Aquarius II then stay well away.
really I didnt know the aquarius was bad
Sorry about that
Reserator=Absolutely silent
Innovatek=very quit
