Best lowest power consumption single slot 1080p graphics card
TheNachoman180
77
Hello I need a graphics card that uses very low power, is single slot, is nvidia and can play back 1080p blu ray without any lags. And maybe netflix and hulu. It cannot be amd and it must draw all power from the card slot and use ultra little power.
For your requirements, a GeForce GT 610 is what you are looking for.
More than capable of 1080p blu-ray playback, and drawing a maximum of 29W.
Actual power draw in typical use is likely lower.
The GeForce GT 620/630/640 all meet your requirements as well.
The maximum power draw on these cards is higher, but actual power draw while watching a movie is probably very similar.
Hi,
I recently bought a 5670 for my home theatre pc. the reference cooler one is only single slot but maybe quite loud sometimes but you can pick one up on ebay for about 30 quid
Hope this helped
Deren
Thanks GT610 it is. And to just explain why i cant have a 7750 is because the computer is running SoftXPand and i have sli GTX 760s and a 3770k. I have 6 workstations on it and 2 are TVs and i wanted a low power cheap gpu that could run the 2 tvs.
