Best memory stick to combine with my current memory.??
naksasolanki
Commendable
May 29, 2016
I currenly have a Corsair XMS3 — 4GB (1x4GB) DDR3 1333MHz C9 Memory Kit (CMX4GX3M1A1333C9). I want to upgrade the memory of my PC by adding another 4GB or 8GB stick. Please suggest the best memory out there which will combine with my current RAM without any problem, will not render my system unstable and give the best performance. MY system specs are:
Core i-5 -3450,
mobo- Intel DZ75ML-45K
naksasolanki
Commendable
May 29, 2016
but the problem is i can't find the same stick annywhere.. and also i am looking to buy a cheaper stick with same specs as this one is quite expensive for me. Can you please recommend me some other stick?? Thanks in advance..!!
