So I've designed a custom radiator tower for my water cooling set-up via Google Sketchup, as seen here.
The entire glass case, including the top and bottom covers weighs around 70 pounds (about 32kg) @ 10mm (about 3/8") thick glass; it weighs around 90 pounds (about 41kg) @ 13mm (about 1/2") thick glass.
I will most likely just leave the top cover resting on top and not bound, unless it begins vibrating from the fans or anything, in which case I'll just spot glue the corners with a basic glue, this way I can still open it and work/fix any problems that come up later on.
I've heard that E6000 would be best, I know epoxy can hold tons of weight, but I don't know if it would work for glass, I've recently discovered nano470 which can apparently is incredibly strong.
So, what do you all think the best way would be to glue the side and bottom glass panels of the case together and have it hold rigidly without flexing very much?
