Hello,
I am replacing the Cooler Master 200mm fans in my HAF-X case with Noctua equivalents.
So far everything has gone smoothly, but the top plastic piece will not go on with the Noctua fans as they are squared instead of shaved like the Cooler Master.
I feel bad butchering these beautiful fans, but if I can shave off the corners to the inside holes they should clear.
Would a dremel tool with a sanding band work?
Any other suggestions besides keeping oem fans?
I need to shave away the Noctua edges as pictured in blended photo.
Noctua NF-A20 (200mm)
Cooler Master A20030-07CB-3MN-F1 (200mm)
Blended (rough)
Here is what I need to shave or cut away:
Thanks!
Blended (rough)
Thanks!
