Best Micro-ATX case under $100 for water cooling?
DemoScout
14
I'm looking for a new Micro-ATX case to get, preferably with a side panel window. I'd also like to have the option to water cool in the future with the case.
Important specs(?):
Motherboard: ASRock H97M Pro4 Micro-ATX
GPU: Gigabyte R9 290
HDD: Two WD Blue 1TB HDD
Two 120mm Corsair case fans
Current case: Rosewill Line-M Micro-ATX
http://www.corsair.com/en-us/obsidian-series-350d-windowed-micro-atx-pc-case
350D window
Case: Corsair 350D Window MicroATX Mid Tower Case ($108.15 @ Mwave)
Total: $108.15
Generated by PCPartPicker 2015-05-13 16:51 EDT-0400
The Micro ATX case for high-performance system builds:
The Obsidian Series 350D Micro ATX PC case is designed for building compact high-performance systems with Micro ATX and Mini ITX motherboards. The compact size is ideal if space is limited, but there’s plenty of room inside for liquid CPU cooling, dual hard drives, dual SSDs, and...
350D window
Total: $108.15
The Obsidian Series 350D Micro ATX PC case is designed for building compact high-performance systems with Micro ATX and Mini ITX motherboards. The compact size is ideal if space is limited, but there’s plenty of room inside for liquid CPU cooling, dual hard drives, dual SSDs, and dual full-length graphics cards.
Like all Obsidian cases, the 350D is designed for fast and neat builds, with tool-free access and drive installation. Smart features like a native 2.5” SSD cage make the most of its small size, and the cooling-focused interior has five fan mounting points, with room for two 240mm radiators.
