I am working on a PC build and am trying to figure out the best mid-tower case to fit 3 GPUS. I'm trying to go as silent as possible, so I'm hoping to use 1080 Ti Hybrids for the 3 GPUS and have a liquid CPU cooler, so space for the radiators is definitely a plus.
I've tried the Phanteks Enthoo Evolv and currently have everything housed in a Fractal Define R5. both cases are great and were pretty much perfect, except that I couldn't utilize the bottom PCIe slot of the motherboard to fit the third GPU (there wasn't enough vertical space between the bottom slot and the Power Supply) . I'm using a GIGABYTE GA-Z170X-UD5 ATX motherboard.
I'd been told that the NZXT H440 would be able to fit 3 GPUs on an ATX board, but as I've already bought two cases unsuccessfully, I figured I'd make a post and see if anyone had suggestions.
Any suggestions & help would be thoroughly appreciated. I also wanted to mention that if this build seems impossible on a mid-tower, any suggestions for a more compact full tower would also be very helpful. Thanks so much
