Best Mini/Micro ITX case for Noise and Water Cooling
Edgerunner
109
So I came into some $$$ in Oct and did the Cyber Monday shopping deal.
Ryzen 7 1700X
Reference 1080 ti
Vengeance LPX (2 x 8GB) DDR4-3000
SAMSUNG 850 EVO M.2 2280 500GB
EK Fluid Gaming A240G
I also got a B350 MB but planning on replacing it.
I popped it all in my old Corsair 600t and it works Great but I am planning on going Small and Silent with a new case.
What Mini/Micro case gets me the best Bang for my Buck if I want to go Silent? With the EK waterblock Vertical GPU mounting isn't an issue and I will also be putting some $$$ towards quiet fans for the 240mm radiator.
Side Window not required on the case.
Also which MOBO would you suggest to go in it? Only requirements would be a good amount of USB connections.
