So I need to set-up a whole new system and am looking for small and powerful. After reading Best mini-Pcs 2015, it looks like the Intel Core i7-powered NUC5i7RYH, 256GB SATA M.2 SSD (or PCIe x4 SSD), with 8GB of RAM might be a good fit.
BUT. I am not a computer expert and have to rely on local advice. Here's what I've been told: "Intel HD is usually on chip and can't be upgraded in NUC's. While the newest generation of 6100 is a lot better than previous generations it is still nothing compared to a decent dedicated GPU card. The NUC will run Illustrator, but the question is, how well? And if you ever need to upgrade you will have to replace the computer".
Is this good advice, or uninformed chatter? I'd like to determine if it's foolish to use the NUC as the basis of my workstation. Here's what I keep open and running on my desktop, at the same time:
- many browser instances
- Word
- Adobe illustrator
- Evernote
Can anyone out there help me set up a system in a small package that will handle all this? Or should I just give-up the idea and look for another small form but not mini?
- Word
- Adobe illustrator
- Evernote
