best mobo for overclocking i5-2500k
XxskaterjerkxX
52
Hey need help deciding on a mobo for my i5. i want to start overclocking and taking advantages of this processor . im looking for a mobo $100-$150 and can overclock to 4,5Ghz
Get this one, use the $40 instant off promo code
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130645&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
The motherboard just needs to have decent quality and not be a thin early gen board. Honestly overclocking is more CPU dependent, some chips clock better than others. All you can really do is make sure it's well cooled and give it a Z77 platform.
Here is a list of Z77 boards, usually I stick with Asus, ASRock, Gigabtye, and MSI in that order (all good companies) just look through each board in a new tab and see if it has all the features you want.
http://pcpartpicker.com/parts/motherboard/#sort=a6&c=52
so would these 2 choices be good ?
1.http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2332609&CatId=6976
or
2.http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2332617&CatId=6976
