I have an MSI laptop running a GTX 980 8gb card spec as per below. I want to run an external monitor. What are my options - ideally I would like an IPS montior with GSync - as large as possible (replacing an old 23in) - maybe widescreen. I suspect it won't run 4k but just want to run games in high settings at a decent framerate (60+ fps is fine) - preferably higher resolution that full HD 1080. Budget not too much of an issue - say £400 to £900)
Any ideas?
Many thanks!
System name: MSI
[Display]
Operating System: Windows 10 Home, 64-bit
Processor: Quad i-7 6820HK CPU @ 2.70 GHz
Installed RAM: 32 Gb
DirectX version: 12.0
GPU processor: GeForce GTX 980
Driver version: 388.00
Direct3D API version: 12
Direct3D feature level: 12_1
CUDA Cores: 2048
Core clock: 1140 MHz
Memory data rate: 7000 MHz
Memory interface: 256-bit
Memory bandwidth: 224.00 GB/s
Total available graphics memory: 24552 MB
Dedicated video memory: 8192 MB GDDR5
System video memory: 0 MB
Shared system memory: 16360 MB
Video BIOS version: 84.04.88.00.4E
IRQ: Not used
Bus: PCI Express x16 Gen3
Device ID: 10DE 161A 116F1462
Part Number: 2724 0020
Any ideas?
Many thanks!
System name: MSI
[Display]
CUDA Cores: 2048
IRQ: Not used
