Best monitor for gaming?
xSwamii
5
Alright, I need a new monitor for gaming. I'll be using it to play PC and Xbox. I want it the resolution to be 1920x1080. It needs to have AT LEAST two inputs. And I want it to have a 2ms response time. (Fairly standard gaming requirements). My budget is about 150-200$. (I can go a little over that if necessary). What do you guys think the best monitor I can get is? Please help!
Not sure if you are in the US or not but if you can i recommend this one its in canadian dollars not sure if our exchange is still the same or not
http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236313
I have 3x of them and they are very quick for response times. I do realize it is probably going to be above your price range but for response and at 144hz it has you more than covered. Comes with displayport, hdmi, and dvi on the monitor.
http://www.amazon.com/VG248QE-24-Inch-Screen-LED-lit-Monitor/dp/B00B2HH7G0
This one looks like the US site.
