Best Monitor For Gaming?
100000th
12
I plan on building a gaming rig soon and was looking at a few monitors. I was curious as to which one would be better. Any other recommendations under $200 would be much appreciated! I'm looking for quality and reliability.
I had planned on getting this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236153
But then I also saw that there were other monitors that looked to be better:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236358
and
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236305
Thank you for everyone's help!
I'd skip the VX228H cuz it is 21.5" whereas the others are 23" and 24". If I had to pick between them, and the price seems to be the same, then I'd go with whichever design I like better. So, I'm leaning towards the 23" one.
Another one to consider:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009483&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
The ones you chose were TN panels, which are fast, but how about a IPS that is decently fast? (like the above Acer)
