Best monitor for movies...?
chazzy2501
I need a widescreen lcd monitor that performs best with movies.
This is my no.1 priority! No spreadsheets or Gaming just movies!
I want the impossible True blacks, massive contrast ratios and perfect colour.
also a monitor that doesnt change every 10 degrees.
Size isn't important (19" fine) but doing 720p is a must (i don't need 1080p)
I've been looking at dell LCDs as this is all I really know. I find video playback of adverts amazing but dark scenes like opening of matrix awful.
(p.s. I notice this on most flat TV's at the moment why do people buy em'?)
Anyone know what I need?
Hello
the best monitors for movies are the wide ones but size 19 is to small you should go to size 20 or 22 .
size 20
ViewSonic VP2030b
http://www.gcn.com/print/25_20/41321-1.html
Nec 20WGX²
http://www.behardware.com/articles/610-1/nec-20wgx-an-ips-equivalent-to-a-2-ms-tn.html
Samsung SyncMaster 215TW
http://www.trustedreviews.com/displays/review/2006/06/26/Samsung-SyncMaster-215TW-21in-Monitor/p1
size 22
http://www.trustedreviews.com/displays/review/2007/03/09/Samsung-SyncMaster-226BW/p1
those are the best monitors at the moment the 20 are better then the 22 because they use better technology(I-SPS or P-MVA).
which is better then the 22 technology(TN).
but on the 22 you will see bigger.
forget abot DELL because of the "panel lottery"
http://www.tftcentral.co.uk/articles/dell_panel_lottery.htm
