T teleadams Sep 12, 2018 1 0 10 Sep 12, 2018 #1 I have an older Hackintosh running I7 950 Bloomfield processor 12gb ram. What would be the best choice monitor for my system? The uses would be internet browsing, movies, light photo editing. Budget <$250. Thanks.
Solution hang-the-9 Sep 12, 2018 https://www.newegg.com/Product/Product.aspx?Item=1B4-009M-000T2&cm_re=27_inch_monitor_1440p-_-1B4-009M-000T2-_-Product would be good for you, basic IPS screen with a higher than budget resolution at 1440 which would help with editing since you can fit more on the screen.
hang-the-9 Titan Mar 25, 2010 60,368 1,081 152,940 Sep 12, 2018 Solution #2 https://www.newegg.com/Product/Product.aspx?Item=1B4-009M-000T2&cm_re=27_inch_monitor_1440p-_-1B4-009M-000T2-_-Product would be good for you, basic IPS screen with a higher than budget resolution at 1440 which would help with editing since you can fit more on the screen. Upvote 0 Downvote Solution
