Best Motherboard for i5-4460 upgrade
chain220
220
I got an i5-4460 at a very discounted price from a local shop, to go in my build. I knew the current build has an 1155 socket in it, and now I'm in the market for a motherboard. I'm not looking for anything fancy or expensive, I just need it to make this work at the moment.
Here's the build:
PCPartPicker part list: http://pcpartpicker.com/p/PRZP6h
Price breakdown by merchant: http://pcpartpicker.com/p/PRZP6h/by_merchant/
CPU: [strike]Intel Pentium G860 3.0GHz Dual-Core Processor[/strike] Intel Core i5-4460 3.2GHz
Motherboard: [strike]MSI H61M-E33/W8 Micro ATX LGA1155 Motherboard[/strike] Replacing
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive
Video Card: XFX Radeon HD 7850 2GB Video Card
Case: NZXT Gamma Classic (Black) ATX Mid Tower Case
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply
Do you have a certain budget in mind? If not how about a microATX motherboard with the H97 chipset? The following is a solid motherboard:
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($84.98 @ Newegg)
Total: $84.98
The motherboard will be compatible with your i5 and forward compatible with Intel's to-be-released 5th generation (Broadwell) processor too.
All the best.
Total: $84.98
All the best.
I appreciate both answers, Obnoxious that fit perfectly into my budget at the start of the idea. It (somehow.. 😀) has expanded as I looked around and I'm gonna go with the H97-Plus. Thanks both of you.
