T TheRixster123 Reputable May 17, 2015 19 0 4,510 Jun 8, 2015 #1 What's the ideal motherboard to go with the intel i5-4690. I need it to be under £80?
Solution S S Suztera Jun 8, 2015 http://uk.pcpartpicker.com/part/asrock-motherboard-h97pro4 There are other choices: http://uk.pcpartpicker.com/parts/motherboard/#s=24&f=2&c=100&sort=a8&page=1
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,784 1,846 159,590 Jun 8, 2015 #2 PCPartPicker part list / Price breakdown by merchant Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard (£69.56 @ Scan.co.uk) Total: £69.56 Prices include shipping, taxes, and discounts when available Generated by PCPartPicker 2015-06-08 21:36 BST+0100 Upvote 1 Downvote
S Suztera Polypheme Mar 18, 2014 12,729 0 60,960 Jun 8, 2015 Solution #3 http://uk.pcpartpicker.com/part/asrock-motherboard-h97pro4 There are other choices: http://uk.pcpartpicker.com/parts/motherboard/#s=24&f=2&c=100&sort=a8&page=1 Upvote 0 Downvote Solution
Jon-Doe Reputable Jun 6, 2015 139 0 4,710 Jun 8, 2015 #4 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157528 Upvote 0 Downvote
Eximo Titan Ambassador May 27, 2010 27,854 5,455 144,340 Jun 8, 2015 #5 Jon-Doe : For that price tag I recommend MSI A88X-G45 Gaming And so does Tom's Hardware- http://www.tomshardware.com/reviews/a88x-socket-fm2-motherboard,3764.html Might want to stick with motherboards that the CPU will actually fit in. Upvote 0 Downvote
Jon-Doe Reputable Jun 6, 2015 139 0 4,710 Jun 8, 2015 #6 Eximo : Jon-Doe : For that price tag I recommend MSI A88X-G45 Gaming And so does Tom's Hardware- http://www.tomshardware.com/reviews/a88x-socket-fm2-motherboard,3764.html Might want to stick with motherboards that the CPU will actually fit in. Yeah, completely ignore that comment, I thought it was 1150. SLOPPY Upvote 0 Downvote
