[SOLVED] Best motherboard for i7-11700K CPU?
Sebubble
99
I'm upgrading my whole computer and someone has made me a build but I just wanted a second opinion on the motherboard as I believe my current motherboard is the component that has caused the whole system to stop working... so I want to be sure I get a really good one this time.
I also want it ready for future upgrades, especially when it comes to graphics card. I have RTX 2070 at the moment but might want to upgrade in a year or so.
Current suggestion for motherboard is Gigabyte Z590 GAMING X ATX Motherboard for Intel LGA 1200 CPUs
Friend of mine went Asus Prime Z590-a, i went Asus z590 Tuf Gaming for ps2 port (i like my ps2 keyboard :) ) and was not a feature on the Prime. We're both running i5s though but that won't matter at all concerning higher core processors.
Both are solid boards and audio is great. For you if ps2 isn't something you use anymore then go the Prime.
