Question Best PC build for less than 1500$?
Mar 24, 2019
13
Hello.
I want to build a high end gaming PC for 1500$ or less. Anyone can help me?
I need to build the rig from zero, the only things I don't need in the build are an SSD for the OS and an OS.
Any links, tips and other things are appreciated.
Cheers!
CPU: Intel - Core i5-9600K 3.7 GHz 6-Core Processor ($264.89 @ OutletPC)
CPU Cooler: Scythe - Mugen 5 Rev. B 51.17 CFM CPU Cooler ($51.89 @ OutletPC)
Motherboard: ASRock - Z390 Extreme4 ATX LGA1151 Motherboard ($158.98 @ Newegg)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory ($119.99 @ Newegg)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive ($59.78 @ OutletPC)
Video Card: MSI - GeForce RTX 2060 6 GB GAMING Z Video Card ($389.99 @ Newegg)
Case: NZXT - H500 (Black) ATX Mid Tower Case ($69.99 @ Amazon)
Power Supply: SeaSonic - S12III 650 W 80+ Bronze Certified ATX Power Supply ($54.99 @ Amazon)
Monitor: Acer - KG241 Pbmidpx 24.0" 1920x1080 144 Hz Monitor ($176.93 @ Amazon)
Keyboard: Logitech - G213 PRODIGY Wired Gaming Keyboard ($45.88 @ Amazon)
Mouse: Logitech - G403 Prodigy Wired Optical Mouse ($41.99 @ Amazon)
Total: $1435.30
Generated by PCPartPicker 2019-04-06 16:00 EDT-0400
g-unit1111
Here's what I would suggest:
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor ($294.99 @ Amazon)
CPU Cooler: Deepcool - GAMMAXX GT 29.5 CFM CPU Cooler ($42.31 @ Amazon)
Motherboard: Asus - ROG STRIX B450-F GAMING ATX AM4 Motherboard ($133.98 @ Newegg)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory ($129.99 @ Amazon)
Storage: Samsung - 970 Evo 250 GB M.2-2280 Solid State Drive ($97.41 @ Amazon)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive ($48.76 @ Newegg)
Video Card: Zotac - GeForce RTX 2070 8 GB AMP Extreme Core Video Card ($499.99 @ Amazon)
Case: Phanteks - Enthoo Pro M Tempered Glass (Black) ATX Mid Tower Case ($91.00 @ Amazon)
Power Supply: EVGA - SuperNOVA G2 750 W 80+ Gold Certified Fully-Modular ATX Power Supply ($129.99 @ Amazon)
Total: $1468.42
Generated by PCPartPicker 2019-04-10 13:51 EDT-0400
Here is the list:
CPU: Intel - Core i7-9700K 3.6 GHz 8-Core Processor ($389.99 @ Walmart)
CPU Cooler: Noctua - NH-D14 64.95 CFM CPU Cooler ($74.95 @ Amazon)
Motherboard: Gigabyte - Z390 GAMING X ATX LGA1151 Motherboard ($139.99 @ Amazon)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory ($79.89 @ OutletPC)
Video Card: Gigabyte - GeForce RTX 2080 8 GB WINDFORCE Video Card ($706.98 @ Newegg)
Case: Corsair - 200R ATX Mid Tower Case ($63.04 @ Amazon)
Power Supply: EVGA - SuperNOVA G3 750 W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ Amazon)
Total: $1554.83
Generated by PCPartPicker 2019-04-10 14:06 EDT-0400
If you prioritize performance over the looks then this build will suit you better. Best setup possible around that budget. No compromise build. All high quality components.
WildCard999
What monitor are you going to be using for this build?
If it's 1080P/1440P @144hz+ then you'll want the 9600K/9700K for the higher refresh rate (better performance per core) but for, lets say, 1440P/60hz then the Ryzen 2600/2700 would be fine and would allow for a better GPU.
Here's mine:
CPU: Intel - Core i7-8700 3.2 GHz 6-Core Processor ($294.99 @ Walmart)
Motherboard: ASRock - Fatal1ty B360 Gaming K4 ATX LGA1151 Motherboard ($115.51 @ OutletPC)
Memory: G.Skill - Ripjaws V 16 GB (2 x 8 GB) DDR4-2666 Memory ($74.99 @ Newegg)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive ($58.44 @ OutletPC)
Video Card: MSI - GeForce RTX 2080 8 GB VENTUS Video Card ($699.99 @ Newegg)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case ($94.99 @ Walmart)
Power Supply: Corsair - RMx (2018) 650 W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ Amazon)
Total: $1480.79
Generated by PCPartPicker 2019-04-10 14:55 EDT-0400
Reactions: ocer9999
logainofhades
I added and SSD, for games storage.
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor ($224.89 @ OutletPC)
CPU Cooler: be quiet! - Dark Rock 4 CPU Cooler ($69.99 @ SuperBiiz)
Motherboard: ASRock - X470 Master SLI/AC ATX AM4 Motherboard ($138.88 @ OutletPC)
Storage: Intel - 660p Series 1 TB M.2-2280 Solid State Drive ($114.99 @ Newegg)
Video Card: Zotac - GeForce RTX 2080 8 GB Video Card ($699.99 @ Amazon)
Case: NZXT - H500 (White) ATX Mid Tower Case ($69.99 @ Amazon)
Total: $1498.61
Generated by PCPartPicker 2019-04-10 22:19 EDT-0400
