best pc but very stutter lag fastsync and vsync on input lag
Mar 6, 2018
26
Greetings to your loved ones
I have a big problem
I have a strong system
Graphics 1070 zotak
Cpu 8600 k
ram 16 bus 3200 gsikill
60 Hz display
When I turn on fastsync, I have a lot of lags, although fps is even higher than 100
My friends tell me the 144 Hertz monitor will fix the problem
Now I ask you to solve the problem by buying a monitor?
Meanwhile, the temperature of all parts is normal
CPU up to 4.8 overclocked
Thanks
Yes, without using fastsync, I used vsync off and on. On off, which has a jump page and like a fastsync, in there is a problem with the input lag. Fps goes below 60 and causes the log
Is your monitor a few Hz? You do not have mini stutter? Very tiny legs while moving the mouse
My monitor is 2K 60 Hz. I play BFV on ultra and its smooth as butter.
