Question Best place to get a power(DC) board for HP Spectre x360 - 15t-bl100 ?
King_justin
47
Hi!
Where is the best place to find the DC power port board for HP Spectre x360 - 15t-bl100? I believe it is not soldered to the motherboard and is on it's own physical board. I'm having a hard time finding the part. I've found just the charging port that i can solder, but if possible i would just like to buy it with the board.
If that part isn't available, is there a part that would work in it's place?
Thank you
spanz
21
@King_justin did you find that part number?
My wife has a Spectre x360 that refuses to charge, and i suspect the problem is inside of the case. but i do not want to open it up without the part in my hand. Or did you open yours up and find it was just a bad solder joint at the USBC connector that needed repairing?
