Was planning on getting a pc from specialist in the future but thought i would see what people recommenced first (not comfortable building my own nor do i have the time)
i have all the peripherals i need already. i have looked at overclockers in the past but it seemed over priced to me but i will look again and also check out scan thanksI would look at the likes of Scan UK and Overclockers who have good support and warranty though this tends to be just the base units, so keyboard, mouse, monitor would be separate. I have used both Scan and Overclockers for too many years to count and have rarely had an issue and even then they have sorted things out very fast.
What type of pre built are you looking for?
Edit, there is also PCSpecialists though I have never used them.
thanks for the reply, im looking for something fairly high end around £1000-£1300, already have a pc from a few years ago but it barely runs most new games and demanding games. I built a few different ones on pc specialist but i dont know if that site is good for the money or if i could get better anywhere else. Up for suggestions 😀No problems at all...As to cost, it depends on a few things with the likes of Overclockers and Scan. If it is just a straightforward system with the basics that allow for good 1080p gaming and some work...then £699 gets you i5-9400 + RX580 GPU system and then you can add a little more for more memory etc. But you can also very quickly scale up as well...Also both are good in terms of calling and making changes to better suit.
https://www.overclockers.co.uk/ocuk-gaming-spectra-gaming-pc-intel-core-i5-9400f-fs-1d7-og.html
And options at scan with a Ryzen 3600 start at around £769 though option 16GB instead of 8gb...
https://www.scan.co.uk/products/sca...b-ddr4-4gb-evga-gtx-1650-240gb-ssd-1tb-win-10
If you have a budget, then let us know and we can find you some options...
