Im doing my first build and just wanna know how many fans should i use and where the best place to put the CPU Radiator is? (The radiator is a corsair h100i v2)
Well, the radiator should have zero issues fitting in the front or the top. Personally, I prefer the top. The top helps vent the case, so it also vents case heat, keeping the CPU a little warmer. In the front, it keeps the CPU cooler, but can raise the case temps. I got a good cooling case, so it isn't that much of an issue with case heat.
