Best possible CPU for L775 ASUS P5kPL-SE MB
Kanza
Hello,
I have a old Desktop I wish to get the max out of for a while longer. It has a corsair 600w PSU, and a 8800 ULTRA about to be replaced with a GTX750 Ti OC 2GB GPU.
This is on a ASUS P5KPL-SE Motherboard, with 4GB of DDR2 which is the max.
Present processor is a Q8200 Quad, cannot OC this easily.
Is there any processor I can use that will give me significantly more, I would prefer to not OC due to heat here.
Thanks
Motherboard - http://www.asus.com/Motherboards/P5KPL_SE/
Supported CPU list
LGA775 Intel® Core™2 Processor
This motherboard supports the latest Intel® Core™2 processors in LGA775 package. It also can support Intel® next generation 45nm Multi-Core CPU. With new Intel® Core™ microarchitecture technology and 1600(O.C.)/1333 / 1066 / 800 MHz FSB, Intel® Core™2 processor is one of the most powerful and energy efficient CPU in the world.
If I were U I would buy a used Q9650 it's have a good performance and good price and if U could buy the QX9770 in the same price that's cool too ... Otherwise I prefer to sell your specs and take a new specs (Haswell or Haswell-R)
Here is the CPU support list for that board along with the necessary BIOS version for it to be recognized.
http://www.asus.com/Motherboards/P5KPL_SE/HelpDesk_CPU/
Finding one from that era won't be easy. Ebay is your best hope, I think.
One of the higher numbered C2Q Q9xxx or C2Q Extreme QX Q9xxx processors would be the best you could do... if you can still find one for sale.
