Best Possible Fan setup
Michael Mansour
146
Hey everyone, i just got my first liquid cpu cooler, and it draws cool air from the outside into my case, my case is the aerocool xpredatorx1, and my cooler is the corsair h70, now i have 2 fans mounted on the upper inside part of my case blowing hot air out, also i have 2 fans blowing cold air in on the front, and i have 1 fan blowing air in on my side panel, these are all 120 mm fans, should i switch the directions around, tell me what you think!
Thanks,
Mike
That should be just about the best config. You always want either equal or more intake than exhaust. The intake and exhaust should also be as far away from eachother as possible for most air flow.
