best power supply for Rampage V 10 Edition
usamal
8
hi ,
what will be the best power supply for Asus Rampage V 10 edition , GTX 1080 Ti ?
thank you in advance .
Corsair RM1000i is made by Channel Well Technology and it isn't the best 1kW (1000W) PSU out there. All Seasonic PSUs are made by Seasonic itself since Seasonic is the oldest PSU OEM in the world (they have been in business for over 40 years). While in CPU world the two biggest/best are AMD and Intel, in GPU world two biggest/best are Nvidia and Radeon then in PSU world, two biggest/best are Seasonic and Super Flower.
For 1kW unit, you can go with FSP Aurum PT 1000W,
specs: http://www.fsplifestyle.com/PROP163000605/
review: http://www.tomshardware.com/reviews/fsp-aurum-pt-1000w-power-supply,4184.html
or Seasonic PRIME 1000W 80+ Titanium,
specs: https://seasonic.com/product/prime-1000-w-titanium/
pcpp...
For your build, great quality 750W unit will do fine. Here you have 2 options: 1. If your build is white, go with Seasonic Snow Silent 750W,
specs: https://seasonic.com/product/snow-silent-750/
review: http://www.tomshardware.com/reviews/seasonic-snow-silent-750w-power-supply,4200.html
2. But if your build is black, go with Seasonic PRIME 750 80+ Titanium,
specs: https://seasonic.com/product/prime-750-w-titanium/
review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=481
pcpp: https://pcpartpicker.com/products/compare/LgJkcf,NN648d/
PRIME series is the best that is offered by Seasonic and it's the only PSU series in the world that has 12 years! of warranty.
My Skylake build (full specs in my sig) is powered by Seasonic PRIME 650 80+ Titanium. Seasonic PSUs also power my Haswell and AMD builds.
what about corsair RM 1000 i ? is it good as seasonic ?
pcpp: https://pcpartpicker.com/products/compare/ysYWGX,PxBrxr/
I, personally, would go with Seasonic 1kW unit since it's the best Seasonic offers. While having premium price, you'll also get the best efficiency there is (80+ Titanium) with 12 years of warranty. FSP 1kW PSU is more budget oriented (aka cheaper) with less efficiency (80+ Platinum) and comes with 7 years of warranty.
