This is the cheapest I'd recommend which is currently $36 after rebate. Although if you look at the price history graph, it will go down to $25 regularly. Horse poop they are not. This is good quality. http://pcpartpicker.com/part/corsair-power-supply-cmpsu430cxv2
I can't believe you would even post diablotec or hec. Niether of those can even supply their rated power. At least go with a antec vp 350 or 450 which is $23 and $31 respectively. http://us.ncix.com/products/?sku=62871&vpn=VP350&manufacture=Antec
http://us.ncix.com/products/?sku=62331&vpn=VP450&manufacture=Antec
i did want to get the antec vp450, but they are out of stock! It was only $30! this was my build: http://pcpartpicker.com/p/qftH and i don't know how much power i need.
It has nothing to do with making me feel better if you buy a shitty psu the chances of killing your hardware are high i agree with samuelspark that is as cheap as it gets so i would suggest you save more money.
I would save up some more money, and get a reliable PSU, such as the Corsairs or Antecs posted. An extra $10 now can save you hundreds down the road.
+1 OP it's not a joke you need to take it seriously!There is no well i only have such and such amount i will spend if that's the case i suggest you not bother with computers.
When you build a system never skimp on the psu its the most important part of the system. As mentioned previously if you get a psu that can't handle the load it will fail and will take other parts with it.
Sorry if i made i sound worse then i wanted it to sound 🙁 I guess i will just wait for the VP450 or take my graphics card down a bit and get the CX430. I seriously do apologize for what i made it sound like.
The Corsair V2 Builder is NOT a good PSU, especially if you plan to stress it. It was made by CWT, not Seasonic, using some inferior Samxon capacitors from a line known to fail early. This information comes from HardwareSecrets then onto the badcaps.org forums. Get the Antec VP-450 (built by FSP, another good OEM) or save up for the Delta-built Earthwatts.
