I built the box I am typing from with two 256 GB SSDs and two 2 TB SSHDs.
- I did the RAID 0 SSDs to try "one more time" if i could realize and actual performance benefit on the desktop.
- I did the RAID 1 SSHDs for redundancy as this box serves as a CAD workstation, home office server (4 machines), home data and media server (4 machines) my personal gaming box and my son's (pilot) flight sim.
RAID 0 SSDs - As proved true every other time I have built a RAID system, the results again agreed with every review RAID 0 analysis on the desktop. There is no real performance benefit to be gained. Of course if your goal is to get your name oin web site leader boards for storage benchmark performance then go at it .. but if the goal is to actually see an increase in productivity or anything else useful, you will be disappointed. I had hoped to see an advantage in loading / manipulating large CAD / Image files, but such never materialized.
There were problems and Samsung will provide no tech Support on their Pro SSDs because RAID is "not supported". The Samsung utilities will not work when an array is installed. With nothing to be gained and too many headaches to deal with for which i could get no assistance from Samsung, I broke the array. I now have 1 SSD with OS and programs and 2nd SSD has a backup OS and fav games.
RAID 1 SSHDs - here the array worked as designed but was somewhat problematic as 2nd drive would sometimes just disappear. On top of that, problems with the Asus Z87 Maximus Formula board (BIOS Clock Freeeze Bug) made management difficult when it would freeze. To reduce the management overhead, i broke the array and installed Fbackup. The utility backs up the 1st SSHD to the 2nd once daily. I thought about increasing the frequency but our office load just doesnt warrant same, it works flawlessly.
In short I gained no advantage from either array in any observable way wile the management effort was burdensome. As is, the system is more resistant to problems, suffers no performance drop and makes life a lot easier.
The following is a THG post that is over 8 years old ... I have tried RAID 0 three times since then and nothing has changed. I expect however that being so old, some of the links must be dead by now.
http://en.wikipedia.org/wiki/RAID_0#RAID_0
RAID 0 is useful for setups such as large read-only NFS servers where mounting many disks is time-consuming or impossible and redundancy is irrelevant.
RAID 0 is also used in some gaming systems where performance is desired and data integrity is not very important. However, real-world tests with games have shown that RAID-0 performance gains are minimal, although some desktop applications will benefit.[1][2]
http://www.anandtech.com/printarticle.aspx?i=2101
"We were hoping to see some sort of performance increase in the game loading tests, but the RAID array didn't give us that. While the scores put the RAID-0 array slightly slower than the single drive Raptor II, you should also remember that these scores are timed by hand and thus, we're dealing within normal variations in the "benchmark".
Our Unreal Tournament 2004 test uses the full version of the game and leaves all settings on defaults. After launching the game, we select Instant Action from the menu, choose Assault mode and select the Robot Factory level. The stop watch timer is started right after the Play button is clicked, and stopped when the loading screen disappears. The test is repeated three times with the final score reported being an average of the three. In order to avoid the effects of caching, we reboot between runs. All times are reported in seconds; lower scores, obviously, being better. In Unreal Tournament, we're left with exactly no performance improvement, thanks to RAID-0
If you haven't gotten the hint by now, we'll spell it out for you: there is no place, and no need for a RAID-0 array on a desktop computer. The real world performance increases are negligible at best and the reduction in reliability, thanks to a halving of the mean time between failure, makes RAID-0 far from worth it on the desktop.
Bottom line: RAID-0 arrays will win you just about any benchmark, but they'll deliver virtually nothing more than that for real world desktop performance. That's just the cold hard truth."
http://www.techwarelabs.com/articles/hardware/raid-and-gaming/index_6.shtml
".....we did not see an increase in FPS through its use. Load times for levels and games was significantly reduced utilizing the Raid controller and array. As we stated we do not expect that the majority of gamers are willing to purchase greater than 4 drives and a controller for this kind of setup. While onboard Raid is an option available to many users you should be aware that using onboard Raid will mean the consumption of CPU time for this task and thus a reduction in performance that may actually lead to worse FPS. An add-on controller will always be the best option until they integrate discreet Raid controllers with their own memory into consumer level motherboards."
http://www.hardforum.com/showthread.php?t=1001325
"However, many have tried to justify/overlook those shortcomings by simply saying "It's faster." Anyone who does this is wrong, wasting their money, and buying into hype. Nothing more."
http://jeff-sue.suite101.com/how-raid-storage-improves-performance-a101975
"The real-world performance benefits possible in a single-user PC situation is not a given for most people, because the benefits rely on multiple independent, simultaneous requests. One person running most desktop applications may not see a big payback in performance because they are not written to do asynchronous I/O to disks. Understanding this can help avoid disappointment."
http://www.scs-myung.com/v2/index. [...] om_content
"What about performance? This, we suspect, is the primary reason why so many users doggedly pursue the RAID 0 "holy grail." This inevitably leads to dissapointment by those that notice little or no performance gain.....As stated above, first person shooters rarely benefit from RAID 0.__ Frame rates will almost certainly not improve, as they are determined by your video card and processor above all else. In fact, theoretically your FPS frame rate may decrease, since many low-cost RAID controllers (anything made by Highpoint at the tiem of this writing, and most cards from Promise) implement RAID in software, so the process of splitting and combining data across your drives is done by your CPU, which could better be utilized by your game. That said, the CPU overhead of RAID0 is minimal on high-performance processors."
Even the HD manufacturers limit RAID's advantages to very specific applications and non of them involves gaming:
http://westerndigital.com/en/products/raid/http://westerndigital.com/en/products/raid/
