Best processor and motherboard for GTX 970
(INTEL)
If you can afford to. I would get these two $600~:
Intel Core i7-5820K Haswell-E 6-Core 3.3GHz LGA 2011-v3
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117402
ASRock X99 Extreme4
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157543
If you're in the mid-high range budget get this $450~:
Intel Core i7-4790K Devil’s Canyon Quad-Core 4.0GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117369
ASUS H97-PRO GAMER LGA 1150
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132415
Mid range budget $320~:
Intel Core i5-4690K Devil's Canyon Quad-Core 3.5GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117372
MSI B85-G41 PC Mate LGA 1150...
Budget budget budget. If its a lower end budget, I'd recommend a MSI 970 Gaming MOBO and a FX6300. Thats what I have for my 970, runs great. Mind you, mines on water cooling at 4.6 GHz. Add in water cooling if possible or just get a FX 8350.
(INTEL)
ASRock X99 Extreme4
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130699
Low-Mid Range $200~:
Intel Core i3-4160 Haswell Dual-Core 3.6GHz LGA 1150
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117447
GIGABYTE GA-H97M-HD3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128731
Low End Build $100~:
Intel Pentium G3220 Haswell Dual-Core 3.0GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116950
GIGABYTE GA-H81M-S1
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128770
There's always some wiggle room. Theres alot of motherboards to pick from. Just do your research and find what works best for you. Also AMD is a good choice for budgets.
